Help Solve a Clamper Problem - No Homework Involved!
  • Thread starter PainterGuy
  • Tags
    Homework
In summary: The voltage on the output will be the difference between the applied clamped voltage and the bias voltage.
PainterGuy
940
70
hi everyone, :wink:
please help me with this clamper problem and please also note that it has nothing to do with home work. if i understand this problem i can understand the overall function of any clamper (at least this what i think :smile:). please take a look on link "1". it has also my questions there. we start from where the capacitor s fully charged. i have drawn that point on the diagram (well i can be wrong, so take caution :smile:). i wouldn't repeat my question here because i believe you will understand them better there on the diagram.
one question i will ask here: what is R doing there? i mean what is its function?
1- this is the modified diagram: http://img860.imageshack.us/img860/359/ex28modified.jpg
2- this is the original one: http://img833.imageshack.us/img833/7397/ex28original.jpg
i will be very much grateful if you will help me out with this problem. please don't confuse me.:-p
cheers :smile:
i didn't know it will take that much time to receive help here, a place full of geniuses and good people!:rolleyes::rolleyes:
Hi.. i think this could be a bit useful for getting the answer to the use of resistance in the circuit..A Clamper circuit uses a capacitor, resistor and a diode to fix an ac waveform to a DC level. This is accomplished by the quick charging of a Capacitor through a diode but the discharge path is through a large resistor. Due to RC time contants, the capictor is not geven enough time to discharge befor the next charge arrives thus acting as a voltage doubler. TC= Time Constant = Resistance in Ohms times the Capacitance in Faraday that is measured in seconds. It takes 5 Tc's to fully charge. By adding a DC Bias, we are now able to set a new clamping point other that the 0 Volt reference.
FAQ: Help Solve a Clamper Problem - No Homework Involved!
What is a clamper problem?
A clamper problem refers to an electrical circuit issue where the output voltage is not at the desired level. This can occur when the input signal is asymmetric and needs to be shifted to a specific level.
How do I know if I have a clamper problem?
You may have a clamper problem if your circuit is not producing the desired output voltage, or if there is a noticeable shift in the waveform. You can also use a multimeter to measure the voltage levels and compare them to the desired values.
What are the common causes of a clamper problem?
There are several potential causes of a clamper problem, including incorrect component values, faulty or damaged components, incorrect connections, and incorrect biasing. It is important to carefully check all components and connections to find the root cause of the problem.
How can I solve a clamper problem?
The first step in solving a clamper problem is to identify the cause. This can be done through careful inspection of components and connections, as well as using a multimeter or oscilloscope to analyze the circuit. Once the cause is identified, it can be addressed by replacing faulty components, correcting connections, or adjusting biasing.
Is it possible to prevent a clamper problem?
While it is not always possible to prevent a clamper problem, there are some steps that can be taken to reduce the likelihood of it occurring. These include using high-quality components, double-checking all connections, and carefully designing and testing the circuit before implementation. Regular maintenance and troubleshooting can also help prevent and address any potential clamper problems.
