Help solving a rational inequality
In summary: If we choose $a=0$ then we get $-\frac{5}{2} < 0$ which is correct and $a=-3$ gives $\frac{2}{-1} < 0$ also correct. So the solution is $a \in (-2, \frac{3}{2})$
arl2267
Solve the rational inequality (a-5)/(a+2) < -1.This is what I got so far:
a-5/a+2 = -1
a-5= -a-2
0= -2a+3
subtract 3 from both sides:
-3=-2a
Divide by -2
3/2=a
I know that the answer is (-2, 3/2), but I'm not sure where the -2 in the answer comes from. Thanks!
Mathematics news on Phys.org
You don't want to multiply through by an expression containing the variable, since it may be either negative or positive. I recommend proceeding as follows:
$\displaystyle \frac{a-5}{a+2}<-1$
Add through by 1:
$\displaystyle \frac{a-5}{a+2}+1<0$
Combine on the left:
$\displaystyle \frac{2a-3}{a+2}<0$
Now, this gives you two critical numbers obtained from the roots of the numerator and denominator. The sign of the expression can only change across these points.
They are: $\displaystyle a=-2,\,\frac{3}{2}$
Now, on a number line mark these points, giving you 3 intervals to test, so pick a test point from within each interval and then check the sign of the expression at these test points. If the sign of the expression is negative, then that interval is part of the solution. Since the inequality is strict, all intervals will be open.
arl2267 said:
(a-5)/(a+2) < -1This is what I got so far:
a-5/a+2 = -1
a-5= -a-2
0= -2a+3
-3=-2a
Divide by -2
3/2=a
You have to be wary with inequalities because it changes direction if you multiply or divide by a negative so ideally we don't want to multiply across the inequality.
$\dfrac{a-5}{a+2} < -1$
$\dfrac{a-5}{a+2} + \dfrac{a+2}{a+2} < 0 $
$\dfrac{2a-3}{a+2} < 0$
For the LHS to be negative the numerator and denominator must have different sign. Points to check are $\frac{3}{2}$ and $-2$ leading to the intervals
$ a < -2 $
$-2 < a < \frac{3}{2}$
$a > \frac{3}{2}$
FAQ: Help solving a rational inequality
What is a rational inequality?
A rational inequality is an inequality that involves rational expressions, which are fractions with variables in the numerator and denominator. This type of inequality can be solved by finding the values of the variable that make the fraction equal to zero, and then determining which values make the fraction positive or negative.
How do I solve a rational inequality?
To solve a rational inequality, first find the values of the variable that make the fraction equal to zero by setting the numerator equal to zero and solving for the variable. Then, plot these values on a number line and test points in each interval to determine if the fraction is positive or negative. The intervals where the fraction is positive are the solutions to the inequality.
Can I use the same steps to solve all rational inequalities?
Yes, the same steps can be used to solve all rational inequalities. However, some inequalities may require additional steps, such as factoring or finding common denominators, before following the standard steps of solving for the variable and testing intervals.
What are the common mistakes to avoid when solving a rational inequality?
Some common mistakes to avoid when solving a rational inequality include forgetting to set the numerator equal to zero, incorrectly determining the intervals where the fraction is positive or negative, and not checking for extraneous solutions. It is important to carefully follow the steps and check your work to avoid these errors.
Can I check my solution to a rational inequality?
Yes, you can check your solution to a rational inequality by plugging in the values from each interval into the original inequality and seeing if the inequality is true. If the inequality is true for all values in the interval, then the solution is correct.
