Help Solving Integral of sqrt(2 - x^2) dx
  • Thread starter -JammyDodger-
  • Tags
    Dx Integral
In summary, the homework statement said to use the substitution x = a sin theta. The homework equations said to use the integral of (Top limit = 1; Bottom limit = 0) sqrt(2 - x^2) dx. The attempted solution said to let x = sqrt(2) sin theta; so dx = sqrt(2) cos theta dtheta. The integral of: sqrt(2 - 2 sin^2 theta) sqrt(2) cos theta dtheta was then substituted into the original equation. The integral of: (1 + cos2theta) dtheta was then integrated. The correct answer is (pi + 2)/4.
-JammyDodger-
I was absent last friday when we went through it in class, so I'm completely lost when it comes to solving it. If anyone could explain how to do them I'd be extremely greatful. Thanks.
It said use the substitution x = a sin theta.
I'm not sure how to write this, but here it goes:
The integral of (Top limit = 1; Bottom limit = 0) sqrt(2 - x^2) dx
I let x = sqrt(2) sin theta; so dx = sqrt(2) cos theta dtheta.
Then I subbed what I know for x and dx into the original equation -
The integral of: sqrt(2 - 2 sin^2 theta) sqrt(2) cos theta dtheta.
Now I took out 2 from the equation, and put it ouside of the integral -
So now i have -
(2)Integral of: Sqrt(1 - sin^2 theta) cos theta dtheta
And I know that cos^2A + sin^2A = 1; So I can put cos^2 Theta into my equation -
Now I have -
(2)Integral of: sqrt(cos^2 theta) cos theta dtheta.
Removing squareroot, and mulitplying the cos thetas gives me -
(2)Integral of: 1/2(1 + cos2theta) dtheta
then...
Integral of: (1 + cos2theta) dtheta.
then integrating...
[theta + sin2theta/2]
And that's where I'm stuck, I probably did that completely wrong anyway.
Thanks.
P.S. You don't even have to answer this particular question, even if you could work through a similar kind so I could see what to do it'd be perfect.
Thanks.
use a = sqrt(2) and 1-sin2(x) = cos2(x)
Thanks, I think I see where to go now. Would it be possible for someone to put a final answer up? So that way I'll know what to work towards (theres no final answers in the book I am using).
Thanks.
What you did in your first post is correct. All you need to do is either change your theta variable back to x or (better) change the limits of integration. With x= sqrt(2)sin(theta), when x= 1, 1= sqrt(2)sin(theta) so sin(theta)= 1/sqrt(2)= sqrt(2)/2. What is theta? When x= 0, 0= sqrt(2)sin(theta) so sin(theta)= 0. What is theta? Use those as your limits of integration.
Thanks for your reply, I think I have it now. Would you mind telling me what the correct answer is if it isn't too much trouble? See there are no answers on the sheet we were given. For my final answer I got (pi + 2)/4. Is this correct?
Thanks again.
Yes, that is correct.
Thank you.
FAQ: Help Solving Integral of sqrt(2 - x^2) dx
What is the general formula for solving integrals?
The general formula for solving integrals is ∫f(x)dx = F(x) + C, where f(x) represents the function being integrated, F(x) represents the antiderivative of f(x), and C represents the constant of integration.
How do I solve integrals involving square roots?
To solve integrals involving square roots, you can use the substitution method or the integration by parts method. In this particular integral, we can use the substitution x = √(2sinθ) to simplify the integral.
What is the antiderivative of √(2 - x2)?
The antiderivative of √(2 - x2) is arcsin(x/√2) + C. This can be verified by taking the derivative of the antiderivative, which would result in √(2 - x2).
Can I use trigonometric identities to solve this integral?
Yes, you can use trigonometric identities to solve this integral. As mentioned in question 2, using the substitution x = √(2sinθ) will simplify the integral and allow you to use trigonometric identities to solve it.
Is there a shortcut for solving integrals involving square roots?
Yes, there is a shortcut known as the trigonometric substitution method. This involves substituting in trigonometric functions to simplify the integral and then using trigonometric identities to solve it. In this case, using the substitution x = √(2sinθ) would be considered a trigonometric substitution.
