Help spotting trig identities to simplify integration
In summary, the conversation discusses the process of solving an integral involving the square root of 1-cos(t). The speaker initially uses a substitution of u=1-cos(t) and du=du/sin(t). After encountering a t in the integral, they seek help from Wolfram Alpha and discover the use of an arccos substitution. They also mention the use of complex exponentials as a brute force method. The conversation ends with a discussion about the importance of experience and the expectation of prior knowledge in college mathematics courses.
Nikarasu M
Hello,
Say I'm working with ∫ sqrt(1-cos(t)) dt
I end up with a substitution of u = 1-cos(t) and dt = du/sin(t)
sub back in: ∫ sqrt(u) / sin(t) du
Still got a t in there ... hrrmmm
So I go to wolfram alpha for some inspiration and 'show steps':
http://www.wolframalpha.com/input/?i=integrate++sqrt(1-cos(t))
After some bashing about I see what they are doing is valid - but have no idea how to go about spotting what they have done in between the substitution and ending up with an integral only in terms of u.
I need a little sub-'show-working' section - anyone care to show me how the 'ah-hah, that'll work!' moment actually comes about ?
It's simple ?
regards,
N
I need a little sub-'show-working' section - anyone care to show me the 'ah-hah, that'll work!' moment actually comes about ?
It's simple ?
<hunted look> erm, simple? ... no... not usually... it takes lots and lots of practice. The computer is your friend.
In the above case you were on the right track, you just needed to figure out how to write sin(t) in terms of u.
I'm guessing:
[itex]u=1-\cos(t) \Rightarrow t=\arccos(1-u)[/itex]
[itex]du=\sin(t)dt = \sin(\arccos(1-u)) =\sqrt{1-(1-u)^2}[/itex]
... which is where you just have to know the identity: [itex]\sin(\arccos(a))=\sqrt{1-a^2}[/itex]
... what usually happens is that you get desperate and pour through a table of trig identities, trying out likely candidates, until you get one that makes all the headaches go away. The trouble with the inverse trig functions is that they only exist for a limited range.
If you get stuck on trigs, you can always brute-force it by using complex exponentials.
Nice,
Thanks for that - exactly what I needed :-p
I wonder if there is a resource of examples of most/all of these tricks ?
Many textbooks and coursebooks show you a couple of them in (unrelated) examples and then leave you on your own.
I'm at a new university now and it seems there is an expectation this stuff is prior learning. Got to catch up and fast
If you didn't realize about the arccos substitution or didn't want to use it, you may just decide to get rid of those pesky trig functions and see what happens:
[itex]x = r\cos(t)[/itex] ... definition of cosine
[itex]dx=r\sin(t)dt = ry/r = y = \sqrt{r^2-x^2}[/itex] ... pythagoras.
... note: similarity to trig ID if r=1
put [itex]r=1[/itex] ... needed for x=cos(t).
integrand becomes:
[tex]\frac{dx}{\sqrt{1-x^2}}\frac{1}{\sqrt{1-x}}[/tex]... then see if it helps any.
eg. factorize (1-x2)
Several substitutions you may end up with something you can integrate.
If you keep track of the substitutions you may be able to write it up as one transformation and look super-clever.
With experience comes foresight.
Until then, you have to do a lot of messing about.
its been a while tis all...
catching my tail everyday
yep - know the feeling.
Note. 1st year college is mostly about establishing a baseline of prior knowledge ... if you missed or forgot something, the course gives you a heads-up and you get some important experience. You are only expected to be able to look things up ;)
You've got it easy ... I had the same thing without the internet.
I ended up with t then u, s and p substitutions !
but I found a much easier way using:
(the part in parentheses)
Wolfram-Alpha led me down a longer and more arcane path (in terms of the trig identities used) ... bah !
...guess in the long run I don't mind the exercise :rolleyes:
Builds character.
Related to Help spotting trig identities to simplify integration
1. What are trig identities?
Trig identities are mathematical equations that involve trigonometric functions, such as sine, cosine, and tangent. They are used to simplify complex expressions and solve problems in trigonometry.
2. Why are trig identities important?
Trig identities are important because they allow us to simplify complex trigonometric expressions and make calculations easier. They also help us to understand the relationship between different trigonometric functions.
3. How can I spot trig identities to simplify integration?
To spot trig identities for simplifying integration, you should look for common trigonometric expressions, such as sin^2x + cos^2x = 1 or 1 + tan^2x = sec^2x. You can also use the Pythagorean identities and double angle identities to simplify expressions.
4. What are some common trig identities used for integration?
Some common trig identities used for integration include the Pythagorean identities, double angle identities, and half angle identities. These identities can help to simplify integrals and make them easier to solve.
5. How can I remember all the trig identities?
It can be challenging to remember all the trig identities, but practice and repetition can help. You can also make use of mnemonic devices or create flashcards to help you memorize them. Additionally, as you use them more in your calculations, they will become more familiar and easier to remember.
