Help starting a different Op Amp Problem
  • Thread starter Asphyxiated
  • Tags
    Amp Op amp
In summary, the homework statement is trying to find the voltage at the input terminals of a op amp. The student is not sure how to get started and is asking for help. If you make a loop around the + terminal, you can find the voltage. Then you can find the gain (R2/R1) and the output voltage.
Asphyxiated
264
An original picture can be seen http://images3a.snapfish.com/232323232%7Ffp733%3A%3A%3Enu%3D52%3A%3A%3E379%3E256%3EWSNRCG%3D335%3B%3B7%3A542347nu0mrj".
I am not really sure how to start, how would I find out what the voltage is at the two input terminals of this op amp? Typically they would just equal the power source but the power is being divided but the resistors are not in series or parallel so how do I get going here?
If you make a loop around the + terminal, it will give you the voltage. Then you can figure out the gain (R2/R1). Then you can figure out the output voltage, and then get io.
Hey, could you possibly draw on the pic i posted and show me what you mean by 'make a loop around the + terminal'? I missed this lecture in class so I really don't know what I am doing. If i could see an example it would help more but if you will just show me the way it would be very much appreciated.
http://imgur.com/vF77U
Make a loop is the same as saying sum all the voltages in the loop. This is a simply voltage divider, and it will give you the voltage that's present at the + terminal. This is equal to the voltage at the - terminal. The gain of you op amp is a division of two resistors, and there's a sign associated with it. Your book should help you there.
Hey, sorry this took so long to post but I had a project that needed to get done for school. Hopefully you'll respond! Anyway,
Summing the voltages in the loop you get:
[tex] 5000i+10000i=3\rightarrow15000i=3 \rightarrow i=\frac {3}{15000} =.0002 A=.2 mA=200 \mu A [/tex]
voltage drop across the 5k resistor:
[tex] 5000 \Omega * .0002A= 1v [/tex]
so voltage at the terminal is 2v, which is correct according the answer sheet so then to find Vo we can use the fact that the current through the 2k resistor is the same as the current through the 8k resistor like so:
[tex] i_{1}=i_{2} [/tex]
[tex] \frac {V_{s}-V_{1}}{R_{1}} = \frac {V_{1}-V_{0}}{R_{f}} [/tex]
now solve this for Vo:
[tex] R_{f}(V_{s}-V_{1})=R_{1}(V_{1}-V_{0}) [/tex]
[tex] \frac {R_{f}}{R_{1}} (V_{s}-V_{1})= (V_{1}-V_{0}) [/tex]
[tex] -V_{0} = \frac {R_{f}}{R_{1}} (V_{s}-V_{1}) - V_{1} [/tex]
[tex] V_{0} = -\frac {R_{f}}{R_{1}} (V_{s}-V_{1}) + V_{1} [/tex]
[tex] V_{0} = -\frac {8}{2} (1) + 2 = -4+2 = -2v [/tex]
this is also correct. Now I need to find Io and if we apply KCL to the node where Io points we should get:
[tex] i_{0} = \frac {V_{0}}{8000}+\frac {V_{0}}{4000} = \frac {-2}{8000}+\frac {-2}{4000} = -.00075 A = -.75mA=-750 \mu A [/tex]
the answer is suppose to be -1mA which you could round to from -.75mA but since the other answers came out exactly this seems wrong to me. Can I get a little more help?
In your io equation, it's not Vo/8k. You have a voltage missing. Vo/8K assumes that the voltage over your 8K resistor is Vo, but there's a voltage that isn't ground connected to your 8K resistor.
great,
[tex] i_{0} = \frac {V_{0}-V_{1}}{8000} + \frac {V_{0}}{4000} = -.001 a = -1 mA [/tex]
thanks greatly!
FAQ: Help starting a different Op Amp Problem
What is an Op Amp and how does it work?
An Op Amp, short for operational amplifier, is an electronic component that amplifies an input signal to produce a larger output signal. It works by applying a high gain to the difference between the input and reference voltage, making it useful for a variety of applications such as amplification, filtering, and signal conditioning.
How do I choose the right Op Amp for my circuit?
When selecting an Op Amp, it is important to consider factors such as the required gain, bandwidth, input and output voltage ranges, and power supply requirements. It is also important to ensure that the Op Amp has the required amount of stability and noise performance for your application.
What are the common input and output configurations for Op Amps?
The two most common input configurations for Op Amps are inverting and non-inverting. In an inverting configuration, the input signal is applied to the inverting input terminal, while in a non-inverting configuration, the input signal is applied to the non-inverting input terminal. The most common output configuration is a single-ended output, where the output signal is referenced to ground.
How do I troubleshoot issues with my Op Amp circuit?
If your Op Amp circuit is not functioning as expected, there are a few troubleshooting steps you can take. First, check all connections and ensure they are secure. Next, check the power supply to make sure it is providing the correct voltage. You can also test the Op Amp by providing a known input signal and measuring the output. If the output is not as expected, the Op Amp may be damaged and need to be replaced.
Can I use multiple Op Amps in a single circuit?
Yes, it is possible to use multiple Op Amps in a single circuit. This can be useful for creating more complex circuits with multiple stages of amplification, or for creating differential amplifiers. However, it is important to ensure that the different Op Amps are compatible and that the circuit is designed with proper feedback and stability considerations in mind.
