Help to understand second order differential definition
In summary, Poisson discusses infinitesimals in his Treatise on Mechanics, specifically the concept of first and second order infinitesimals. He provides an example of the versine, which is a first order infinitesimal, and how it relates to the chord of an arc of a circle. The chord is represented by the formula chord = diameter * sin (angle), while the versine is represented by 1 - cos (2 * angle). The versine is a second order infinitesimal, as it is of order x^2.
jonjacson
453
38
Hi folks, I am reading Poisson's Teatrise on Mechanics. In the introduction he talks about the infinitesimals.
Let's say A is a first order infinitely small quantity, a differential of the first order, if the ratio of A to B is infinitely small too it means B is an infinitesimal of the second order.
Then he shows the meaning with an example I don't understand:
"For example, the chord of an arc of a circle being supposed infinitely small, the versed sine of the same arc is an infinitely small quantity of the second order, because the ratio of the versed sine to the chord is always the same as that of the chord to the diameter, and consequently becomes infinitely small at the same time as the second ratio."
As far as I know the relation between the chord and the sine is:
I can't see how his defition of ratios fits in the formula to get a second order differential.
Do you see what is he meaning in this example?
THanks!
The reference 'versed sine' is to the versine, which is 1 minus the cosine of the angle.
The chord length of a sector subtending angle ##2x## in a unit circle is ##2\sin x=s\times (x-x^3/3!+x^5/5!-...)##, which is of order ##x##.
The versine is ##1-\cos 2x## = ##1-(1-(2x)^2/2!+(2x)^4/4!-...)=(2x)^2/2!-(2x)^4/4!+...)## which is of order ##x^2##.
Likes jonjacson
FAQ: Help to understand second order differential definition
1. What is the definition of a second order differential equation?
A second order differential equation is a mathematical equation that involves a function and its first and second derivatives. It can be written in the form f''(x) = g(x, f'(x), f(x)), where f''(x) is the second derivative of f(x), and g(x, f'(x), f(x)) is a function of x, f'(x), and f(x).
2. What is the order of a differential equation?
The order of a differential equation is determined by the highest order derivative present in the equation. For example, a second order differential equation contains a second derivative, while a first order differential equation contains a first derivative.
3. How do you solve a second order differential equation?
There are several methods for solving second order differential equations, including the method of undetermined coefficients, the method of variation of parameters, and the Laplace transform method. The specific method used will depend on the form of the equation and the initial conditions given.
4. What are the applications of second order differential equations?
Second order differential equations are used to model a wide range of phenomena in physics, engineering, and other scientific fields. They can be used to describe the motion of particles, the behavior of electrical circuits, and the growth of populations, among many other applications.
5. What is the difference between a second order and a first order differential equation?
The main difference between a second order and a first order differential equation is that a second order differential equation involves a second derivative, while a first order differential equation only involves a first derivative. This means that a second order equation is more complex and may have a wider range of solutions than a first order equation.
