HELP Two point source interference pattern
In summary, the conversation discusses a scenario with two point sources 20cm apart producing 3cm waves at a rate of 8 waves every 1.2 seconds. The questions asked include the number of nodal lines present, the angular deviation of the 3rd nodal line, and the angle between the 3rd and 5th nodal lines. Using the equation (n-1/2) x wavelength, the number of nodal lines on both sides of the right bisector is found to be 14. The angular deviation is calculated using the equation sinx = (n-1/2) x wavelength/d, resulting in an angle of 22 degrees. To find the angle between the 3rd
redbluegreen
2 point sources 20cm apart produce 3 cm waves at a rate of 8 waves every 1.2 seconds
how many nodal lines are present
what is the angular deviation of the 3rd nodal line?
what is the angle between the 3rd nodal line and the 5th nodal line?
Answer for anyone who is wondering:
Nodal lines:
1 = (n-1/2) x wavelength
1 = (n-1/2) x 3
n = 7.17
Nodal Lines on both sides of right bisector, 7.17 x 2 = 14 (rounded down to nearest whole number)
Angular Deviation:
x = sin-1(2.5 x (3/20))
x = 22 degrees
Angle between 3rd and 5th:
Repeat steps above to find angle of 5th nodal line and subtract angle of 4rd from angle of 5th
It is not good enough just to post the question. you must post your attempt at a solution; or if you can't even get started explain why not. Is it that you don't understand some of the terms or concepts? E.g. do you know what a nodal line consists of?
To get you started, try http://www.physicsclassroom.com/Class/light/u12l1b.cfm
FAQ: HELP Two point source interference pattern
What is a two point source interference pattern?
A two point source interference pattern is a phenomenon that occurs when two coherent light sources, such as lasers, produce overlapping waves that create a pattern of alternating bright and dark regions.
How is a two point source interference pattern created?
A two point source interference pattern is created when two coherent light sources are placed close enough together that their waves overlap and interfere with each other. This interference results in the pattern of bright and dark regions.
What factors affect the appearance of a two point source interference pattern?
The appearance of a two point source interference pattern is affected by the distance between the two sources, the wavelength of the light, and the angle at which the waves are intersecting.
What is the significance of a two point source interference pattern?
A two point source interference pattern is significant because it demonstrates the wave properties of light, such as interference and diffraction. It also has practical applications in fields such as physics, optics, and telecommunications.
How is a two point source interference pattern used in research or technology?
A two point source interference pattern is used in research and technology to study the properties of light, such as wavelength and coherence, and to create precise measurements and devices, such as interferometers and optical tweezers, for various applications in science and technology.
