Help understanding basic astronautics?
  • Thread starter snickers1
In summary, the equation used to solve the problem is the orbital velocity equation, v = √(G * M / r). To determine the altitude and velocity of the satellite, the radius of the orbit must be calculated (which is equal to the radius of the Earth), and then the orbital velocity can be found by plugging in the values for G, M, and r. The altitude can then be determined by subtracting the radius of the Earth from the radius of the orbit.
snickers1
Hello,
I am currently studying some introductory concepts involving orbit. Can anyone help me with the equation I would use to solve the following problem:
Assume you wish to place in orbit a satellite that always remains directly above the same point on the Earth's equator. What velocity and altitude must the satellite have at the instant of burnout of the rocket booster?
Thanks for any suggestions!
If you want to have something in orbit above the same place in the equator, this is a special orbit called 'geostationary'. It only works around the equator, and it's done by putting something in orbit such that its own orbital period is the same as that of the Earth rotating on its own axis. So, since the Earth takes 24 hours to rotate, so should your orbital period be 24 hours.
T = 24 hrs. Convert that to seconds, and you get 24hrs*3600sec/hr = 86400sec
Orbital mechanics in your case is actually pretty easy. It's just a matter of thinking about the forces acting on your satellite when it is in orbit. In this case, it's going around in a circle, so you have the centripetal force being caused by the gravitational force of attraction between the satellite and the earth.
Remember that centripetal force Fc = (mv2)/r (where m = mass of satellite, v = speed of satellite in meters per second, and r = radius of orbit ABOVE THE CENTER OF THE EARTH)
Gravitational force is given by: Fg = (GMm)/(r^2) (where G = gravitational constant = 6.67x10-11, M = mass of the earth, which is 5.98x1024 kg, and r and m were defined above).
Set the two forces equal to each other: (mv2)/r = (GMm)/r2
You see that the mass of the satellite cancels out, and you can move the r around to get:
GM = rv2
Now you need to find both the velocity and the radius, which seems impossible with only one equation. (you need to know r and v). However, you can use the fact that the orbital period is 24 hours. You'll just need to convert your speed v into something more manageable.
Remember that speed = distance traveled / time taken. Since we assume it goes in a circle (this is a simplification - orbits are actually ellipses), then the distance traveled in one orbit is the same as the circumference of a circle: dist = 2*pi*r. You can also say that the time taken is the orbital period, which was stated earlier.
Then, you can say that v = 2*pi*r / T
Remember that we were working on the equation GM = rv2
Now replace v to get: GM = (4*pi2*r3)/T2
Then you can solve for r: r3 = GMT2/(4*pi2).
You solve for r by finding the cube root of the right side and put in the values for G and M and T and finally get:
r = 4.2x107m. BUT, this is just the height above the center of the earth. If you want to know how high it is above the SURFACE of the earth, you have to subtract the radius of the earth, which is 6378000m, so you get 35 873km above the earth, or 35 873 000 m above the surface of the earth. Phew! (you can check on wikipedia for geostationary orbit height, and this matches)
Then you can find the orbital speed. Remember that we have figured out that v = 2*pi*r / T Now you just plug in your answer for r (the one that is the radius above the center of the earth), and put in T and you get:
v = 3073 meters / sec = 11061km/hour
I hope that helps!
Hi there,
The equation you would use to solve this problem is called the orbital velocity equation, which is given by:
v = √(G * M / r)
Where:
- v is the orbital velocity in m/s
- G is the gravitational constant (6.67 x 10^-11 m^3/kg*s^2)
- M is the mass of the Earth (5.97 x 10^24 kg)
- r is the radius of the orbit (in this case, the distance from the center of the Earth to the satellite's orbit)
To determine the altitude and velocity of the satellite, you would need to use the following steps:
1. Determine the radius of the orbit: Since the satellite will remain directly above the same point on the Earth's equator, the radius of its orbit will be equal to the radius of the Earth (6,378 km).
2. Calculate the orbital velocity: Using the equation above, plug in the values for G, M, and r to calculate the orbital velocity required for the satellite to maintain its orbit.
3. Convert the orbital velocity to km/h: The orbital velocity calculated in step 2 will be in m/s. To convert it to km/h, simply multiply by 3.6.
4. Determine the altitude: To find the altitude of the satellite, subtract the radius of the Earth (6,378 km) from the radius of the orbit (also 6,378 km). This will give you the altitude in kilometers.
So, to answer your question, the satellite must have an orbital velocity of approximately 7.9 km/s and an altitude of 0 km (since it will be directly above the Earth's equator).
I hope this helps! Let me know if you have any other questions.
FAQ: Help understanding basic astronautics?
1. What is astronautics?
Astronautics is the branch of science and engineering that deals with the design, development, and operation of spacecraft and related technology. It encompasses both the study of space and the practical application of that knowledge to space exploration and travel.
2. How does astronautics differ from aeronautics?
Astronautics primarily focuses on objects and technology that operate in the vacuum of space, while aeronautics deals with objects and technology that operate within Earth's atmosphere. However, the two fields are closely related and often overlap in their principles and technologies.
3. What are the key components of astronautics?
The key components of astronautics include rocket propulsion, spacecraft design and construction, orbital mechanics, space navigation and communication, and human factors in space travel. These components work together to enable the successful launch, operation, and return of spacecraft in space.
4. What is the significance of astronautics?
Astronautics plays a crucial role in expanding our understanding of the universe and our place in it. It has enabled humans to reach and explore other planets, study the Earth from space, and conduct scientific experiments in microgravity. It also has practical applications such as satellite technology for communication, navigation, and weather forecasting.
5. How can I learn more about astronautics?
There are many ways to learn more about astronautics, including studying aerospace engineering or related fields in college, attending workshops and conferences, and reading books and articles on the subject. You can also follow updates and news from space agencies and organizations like NASA and the European Space Agency.
