tx_kurt
- 3
- TL;DR Summary
- I am unable to follow the argument used in L&L's Classical Theory of Fields to show that an infinitesimal interval is invariant. Help appreciated.
I just decided to look at Landau & Lifshitz' Classical Theory of Fields (English version, 4th ed), and I am a bit embarrassed to be confused already on page 4&5 of this book. The book can be viewed on archive.org.
The goal of this section of the book is to show ##s = s'## starting from only the principle of relativity and the existence of a maximum signal speed c. The interval s is defined and since c is the same in all frames if follows that ##s = 0## implies ##s' = 0##. Next, an infinitesimal interval is considered:
##ds^2=c^2 dt^2 - dx^2 - dy^2 - dz^2## and similar in a second inertial frame with primed coordinates. It is argued that ##ds^2## and ##{ds'}^2## must be proportional to each other, and that the proportionality constant can only depend on the absolute value of relative velocity between the two inertial systems: ##ds^2=a(V){ds'}^2##. (Note that although the interval considered is infinitesimal, there is no restriction on the relative velocity between the two systems.) Once this last equation is established, it follows that ##a(V)=1## so that the differential intervals are equal (and finite intervals as well).
But it's this argument that the coefficient ##a(V)## can only depend on the absolute relative velocity between the systems that I don't understand. The text contains the argument "[the coefficient] cannot depend on the direction of the relative velocity, since that would contradict the isotropy of space." But why can't the proportionalty depend on the angle between the relative velocity and ##(dx,dy,dz)## for example?
(Be patient, this is my first post.)
