Help Understanding Response Function $$H(\omega)$$
In summary, a response function is a mathematical representation of a system's response to an input, used to understand and predict its behavior. Understanding response functions is crucial for controlling and optimizing systems. It relates the input and output of a system and can be affected by various factors. Response functions are often represented in the frequency domain for a better understanding of system behavior.
Diracobama2181
75
Let us study a system coupled tho an external field h(t) with the Hamiltonian $$H = H_0 −h(t)A $$
Assume that the perturbation is monochromatic, $$h(t) = h_0 cos \omega t$$, and take the unperturbed density operator to be thermal. With the aid of a suitable average over the period of the perturbation, show that the rate of change of the expectation value of the perturbed Hamiltonian $$H_0$$ equals $$\frac{1}{2}h_{0}^2\omegaχ_{AA}(\omega)$$.
$$χ_{AA}=\frac{1}{2\hbar} Tr{\overline{\rho}[\overline{A(t)},\overline{A(0)}]}$$
$$<B(\omega)>=\sum_{j} χ_{BAj}h_j(\omega)$$ where $$B(\omega)$$ is an operator.
$$<H(\omega)>=\sum_{j} χ_{HAj}h_j(\omega)$$
Where $$χ_{HA}=\frac{1}{2\hbar} Tr{{\rho}[{H(t)},{A(0)}]}$$.
But
$$[H(t),A(0)]=[H_o,A(0)]-[A(t)h,A(0)]=-h_0 cos(\omega t)[A(t),A(0)]$$.
So $$χ_{HA}=-\frac{1}{2\hbar}Tr(\rho h_0 cos(\omega t)[A(t),A(0)])=-h_0cos(\omega t)χ_{AA}$$.
Then $$<H(\omega)>=\sum_{j}-h_0^{2}cos^2(\omega t)χ_{AAj}$$.
Is my reasoning correct thus far? And where would I go from here? Thanks.
Nevermind, figured it out. Thank you though.
Related to Help Understanding Response Function $$H(\omega)$$
1. What is the purpose of a response function?
A response function is used in scientific research to describe the relationship between an input signal and an output signal in a system. It helps to understand how a system responds to different inputs or stimuli, and can be used to make predictions about the behavior of the system.
2. How is a response function different from a transfer function?
A response function and a transfer function are both used to describe the behavior of a system. However, a response function specifically looks at the output of a system in response to a specific input, while a transfer function describes the relationship between the input and output signals in a system.
3. How is a response function typically represented?
A response function is typically represented using a mathematical equation or a graph. The equation or graph shows the relationship between the input signal and the output signal in a system, and can be used to analyze the behavior of the system.
4. What is the significance of the frequency domain in a response function?
A response function can be represented in both the time domain and the frequency domain. The frequency domain representation allows for a more detailed analysis of the system's response to different frequencies of input signals. It is particularly useful in understanding how a system responds to periodic or oscillatory inputs.
5. How is a response function used in practical applications?
A response function is used in a variety of practical applications, such as signal processing, control systems, and data analysis. It can be used to design and optimize systems, as well as to troubleshoot and diagnose issues in existing systems. It is also used in fields such as physics, engineering, and biology to study the behavior of complex systems.
