Help Understanding Trig Equation
  • Thread starter theintarnets
  • Tags
    Trig
In summary, the solution is in the form of ∏/6 + ∏n, 5∏/6 + ∏n, and ∏/2 + ∏n, where n is an integer, because the cosine function is periodic and an even function.
theintarnets
64
Find all possible solutions:
2cos22θ = 1 - cos2θ
I know all my arithmetic is correct, but when it comes to giving the answer, I'm not sure how to write it.
2cos22θ + cos2θ - 1 = 0
(2cos2θ - 1)(cos2θ + 1) = 0
2cos2θ = 1
cos2θ = 1/2
2θ = ∏/3
cos2θ = -1
2θ = ∏
So θ is equal to ∏/6 and ∏/2
But the solutions are supposed to be:
∏/6 + ∏n
5∏/6 + ∏n
∏/2 + ∏n
And I don't understand why. Can someone explain it to me please?
2cos22θ = 1 - cos2θ
2cos2θ = 1
cos2θ = 1/2
2θ = ∏/3
cos2θ = -1
2θ = ∏
∏/6 + ∏n
5∏/6 + ∏n
∏/2 + ∏n
It's because the cosine function is periodic and is an even function.
Even as in cos(-x) = cos x? What do you mean by periodic? Thanks!
cos(x) = cos(x + 2π) = cos(x + 4π) = cos(x + 2πk) , where k is an integer.
Ohhhhhh, I see, thank you! What is sin(x) then, because I know sin is odd, but I'm not sure how that looks.
An odd function means that f(-x) = -f(x). Graphically, f(-x) is just f(x) flipped across the x-axis or y-axis. Also, f(x) has rotational symmetry in that it's unchanged if you rotate it 180°.
Related to Help Understanding Trig Equation
1. What is a trig equation?
A trigonometric equation is an equation that contains trigonometric functions such as sine, cosine, tangent, etc. These equations are used to model and solve real-world problems involving angles and triangles.
2. How do I solve a trig equation?
To solve a trig equation, you need to use algebraic manipulation and trigonometric identities to isolate the variable and find its value. It is important to know the basic trigonometric identities and have a good understanding of algebraic concepts.
3. What are the common trigonometric identities used in solving equations?
Some of the common identities used in solving trig equations include the Pythagorean identities, sum and difference identities, double angle identities, and half-angle identities. These identities help to simplify the equations and make them easier to solve.
4. Can I use a calculator to solve trig equations?
Yes, you can use a calculator to solve trig equations. However, it is important to understand the concepts and steps involved in solving the equations by hand before relying on a calculator. Also, make sure your calculator is set to the correct mode (degrees or radians) when solving trig equations.
5. What are some practical applications of trigonometric equations?
Trigonometric equations are used in various fields such as science, engineering, and navigation. They are used to model and solve real-world problems involving angles and distances, such as calculating the height of a building or the distance between two points.
