NamNodrog
- 3
- Homework Statement
- On a midway ride called The Round Up, participants climb into a cylindrical apparatus and stand upright with their backs against the wall of the cylinder. The apparatus begins to spin, first in the horizontal plane and then tipping into the vertical plane so that the riders’ bodies are parallel to the ground below. Consider a rider of mass 60.0 kg. The radius of the apparatus is 8.0 m and it spins with a period of 4.0 s.
c. What minimum speed must the person be moving with in order to keep from falling away from the side of the cylinder when rotating in the vertical plane? State where in the circle this would occur and draw the appropriate free-body diagram.
- Relevant Equations
- Fc=mv/r, v=2pi/r
I am not too sure as to how to approach part c. of this question. In the vertical plane, the centripetal force is provided by the normal force and the force of gravity. However, the solution to this problem includes a description of the forces at the top of the loop, where the normal force is zero, so that g=v^2/r. I don't understand why there is no normal force at the top of the loop.
Thank you for your help.
