Help with a Kinetic/ Potential Energy problem please
In summary: You truly are an expert summarizer of content, especially when dealing with my poorly written explanation. I am truly grateful for your help. Thanks again.In summary, a sled with a total mass of 50.0 kg is pulled up a frictionless hill with a 10.0° incline using a constant force of 127 N at an angle of 45.0° to the hill. The initial displacement is 104 m and the force of gravity on the sled is -85 N. To find the speed of the sled when it reaches the top, the work done by the pulling force (127 N * cos 45° * 104 m) and the change in gravitational potential energy (-50 kg *
Legal
You are pulling your sister on a sled to the top of a 18.0 m high, frictionless hill with a 10.0° incline. Your sister and the sled have a total mass of 50.0 kg. You pull the sled, starting from rest, with a constant force of 127 N at an angle of 45.0° to the hill. If you pull from the bottom to the top, what will the speed of the sled be when you reach the top?
I'm not sure about these, but these are the few I tried to use...only to no avail :(.
1) ▲ X = 18.0 M/ Sin 10 (Hypotenuse = Opposite/ Sin Ө)
2) Force of Gravity on Sled = m*g*Sin 10
3) Total Work = (Force x Cos Ө) ▲ X
4) W = ▲PE + ▲KE
W= mg(▲Y) + ▲KE
Then I figured once I solved for ▲KE, I could use the following to determine Final Velocity:
5) ▲KE= (1/2)m(v^2)
Or simply v = Square Root(2 x ▲KE)/m
Alternate Equation Used:
Total Work Done = ▲KE = (1/2)m*(Final Velocity^2) - (1/2)m*(Initial Velocity)
I got my initial displacement to be 104 m using Equation #1. Using Equation #2, I got the Force of Gravity on the Sled to be -85 N. So I Added 127 N + -85 N to get a Net Force of 42 N. I then used Equation 3 and plugged in 42 N * Cos 0 (Because there is no angle between the force and displacement) * 104 m to get roughly 4370 J. Using Equation 4, I calculated the change in Potential Energy to be 8830 J (50kg * 9.81 * 18m). This is where I get stuck because I'm certain there can't be a negative change in Kinetic Energy because it is derived from squaring a number.
I then went back and tried to use the result I derived from Equation 3 (4370 J), and I applied this number to the Alternate Equation I provided. I set 4370 J = ▲KE and tried to solve for Final Velocity. I used 0 m/s for Initial Velocity, essentially dropping the second half of the equation to zero, making 4370 J = (1/2) * mass * (FV^2). Solving for the Final Velocity, I received my answer to be 13.2 m/s. This would be quite a feat for a girl to be pulling a 50 kg sled up an incline that fast.
I know I'm messing up somewhere because I have yet to incorporate the 45 degree angle that the Force of the Tension is being applied from. Any help would be greatly appreciated!
Sorry if my explanation was poorly mapped out...I'm still very new to all of these concepts.
Sounds good so far. :approve:
Also good. :approve:
Oooh, not not so good. :cry:
Both the force pulling the rope, and the force of gravity, are both vectors and need to be treated as such. If you are going to add the vectors together, you need to add their respective components together -- not the overall magnitudes. But I don't recommend adding the vectors together for this problem. There is a much easier way that involves conservation of energy.
Ugh. Not following you there. :rolleyes: Perhaps a free body diagram would be a good place to start.
Let's forget about the '42 N' figure, since we've already discussed why that's not correct, and go back to the original problem.
There is a 127 N force that is at an angle of 45o with respect to the displacement vector. If you want to find the work done by the pulling force (which you do want to find), you'll need to find the component of that 127 N force that is parallel with the displacement vector.
(Hint: that's one of the first steps to solving this problem: the work done by the pulling force. The second step is calculating the difference in gravitational potential energy [but this can be a completely separate step from the first step -- and actually the order is unimportant since both steps are independent. You could calculated the gravity part first if you wanted to]. Once you have the total work done, and the change in graviational energy, do you know how you would use them together to find the leftover kinetic energy? :wink:)
[Edit: Oh, by the way Legal, welcome to Physics Forums!]
Wow! Excellent analysis. I thank you for your assistance and I apologize that it took me so long to do so. I greatly appreciate your help.
Related to Help with a Kinetic/ Potential Energy problem please
1. What is the formula for calculating kinetic energy?
The formula for calculating kinetic energy is KE = 1/2 * m * v^2, where KE represents kinetic energy, m represents mass, and v represents velocity.
2. How is potential energy different from kinetic energy?
Potential energy is the energy an object has due to its position or configuration, while kinetic energy is the energy an object has due to its motion.
3. Can you provide an example of a kinetic energy problem?
One example of a kinetic energy problem is calculating the kinetic energy of a car traveling at a speed of 60 mph with a mass of 1000 kg.
4. How can I determine the potential energy of an object?
The potential energy of an object can be determined by multiplying its mass by the acceleration due to gravity (9.8 m/s^2) and its height above the ground.
5. What units are used to measure kinetic and potential energy?
Kinetic and potential energy are both measured in joules (J), which is a unit of energy in the International System of Units (SI).
