hammer123
- 2
- 1
<Re-opening approved by mentor.>
Hi, I've always wondered why when calculating the partition function for a quantum system, we only sum over the eigenstates and not superimposed states. Thus I decided to actually try summing over all normalized states and see what would happen. Feedback is appreciated. (Updated result at the end)
Consider a spin-1/2 system immersed in a constant magnetic field ##B##, with the Hamiltonian
$$ \hat H = - B \hat S_z$$ Consider an arbitrary state decomposed in the eigenstates of ##\hat S_z##
$$| \psi \rangle = \alpha | + \rangle + \gamma e^{i \phi} | - \rangle $$ ##\alpha## and ##\gamma## are taken to be real and greater than zero. The expected energy for this state is $$E_{| \phi \rangle}=\langle \phi | \hat H| \phi \rangle = - \frac {B \hbar} {2} (\alpha^2 - \gamma^2)$$ Now consider the "all-states" partition function of this system, in which all states such as ##| \psi \rangle## are summed over. $$Z = \sum_{| \psi \rangle} \text{exp}[\frac {B \hbar \beta} {2} (\alpha^2 - \gamma^2)]$$ By normalization of ##| \psi \rangle##, this is $$ Z = \sum_{| \psi \rangle} \text{exp}[\frac {B \hbar \beta} {2} (2\alpha^2 - 1)]$$ Explicitly, $$Z = \int_0^{2\pi} \int_0^{1}\text{exp}[\frac {B \hbar \beta} {2} (2\alpha^2 - 1)] d\alpha d\phi$$ The ##\phi## integral is to account for the phase $$Z = 2 \pi ~\text{exp}(-\frac {B \hbar \beta}{2})\int_0^{1}\text{exp}[ {B \hbar \beta}\alpha^2] d\alpha$$ The mean spin in the ##z## direction is then $$\langle m_z \rangle = \frac {1}{\beta} \frac {\partial logZ} {\partial B} = -\frac {\hbar}{2} + \frac {\hbar\int_0^{1} \alpha^2 \text{exp}[ {B \hbar \beta}\alpha^2] d\alpha}{\int_0^{1} \text{exp}[ {B \hbar \beta}\alpha^2] d\alpha} $$ This can be expressed in terms of the ##\text{erfi}(x) = -i \text{erf}(ix)## functions $$\frac {\langle m_z \rangle}{\hbar} = \frac { e^\tau}{\sqrt {\pi \tau}\text{erfi}\sqrt{\tau}} -\frac {1+\tau}{2\tau} $$ where ##\tau = B\hbar\beta##. Can be shown that (according to mathematica)
$$\lim_{\tau \rightarrow \pm\infty} \langle m_z \rangle = \pm \frac {\hbar}{2}$$ Which is good as this corresponds to ## T \rightarrow 0##. However, it appears that $$\lim_{\tau \rightarrow 0} \langle m_z \rangle = -\frac{\hbar}{6}$$ which is not right since this corresponds to the ##T \rightarrow \infty## limit.
So my question is, did I make a mistake or was this entire thing invalid to start with?
Wolframalpha results for the limits:
##\tau\rightarrow-\infty##
##\tau\rightarrow\infty##
##\tau\rightarrow0##
UPDATE:
Okay, so it seems like my initial treatment distinguished the ##| + \rangle## state and that's what caused the non-zero net spin at ##T \rightarrow \infty##. However I'm not really sure why that was so, as far as I can tell I summed over all of the physically distinct states.
Whatever the case, to treat them equally I sum up the expressions for ##Z##, one with ##\gamma## removed and one with ##\alpha## removed$$Z = \sum_{| \psi \rangle} \text{exp}[\frac {B \hbar \beta} {2} (\alpha^2 - \gamma^2)]$$Using ##\alpha^2+\gamma^2=1## $$ =\frac{1}{2} \sum_{| \psi \rangle} \{\text{exp}[\frac {B \hbar \beta} {2} (2\alpha^2 - 1)]+\text{exp}[\frac {B \hbar \beta} {2} (1-2\gamma^2)]\}$$ $$ = \frac{1}{2}\int_0^{2\pi} \int_0^{1}\text{exp}[\frac {B \hbar \beta} {2} (2x^2 - 1)]+\text{exp}[\frac {B \hbar \beta} {2} (1-2x^2)] dx d\phi$$ $$= \pi ~\text{exp}(-\frac {B \hbar \beta}{2})\int_0^{1}\text{exp}[ {B \hbar \beta}\alpha^2] d\alpha+ \pi ~\text{exp}(\frac {B \hbar \beta}{2})\int_0^{1}\text{exp}[ {-B \hbar \beta}\gamma^2] d\gamma$$ The net spin is then $$\langle m_z \rangle = \frac{\hbar}{2}(\frac { e^\tau}{\sqrt {\pi \tau}\text{erfi}\sqrt{\tau}}+\frac { e^{-\tau}}{\sqrt {\pi \tau}\text{erf}\sqrt{\tau}}-\frac{1}{\tau})$$Where as before ##\tau = B\hbar\beta##. This function has the right limits $$\lim_{\tau \rightarrow \pm\infty} \langle m_z \rangle = \pm \frac {\hbar}{2}$$ and, more importantly $$\lim_{\tau \rightarrow 0} \langle m_z \rangle = 0$$ Compared to the net spin derived from only summing eigenstates, ##\langle m_z \rangle = \frac {\hbar}{2}\text{tanh}(\frac{\tau}{2})##, the one derived here converges to ##\pm \frac{\hbar}{2}## more slowly, as expected since the system has more degrees of freedom.Plot of the net spin compared to usual one
UPDATE:
