MHB Help with a statistical inference question regarding MLEs
  • Thread starter Thread starter cmk1300
    Statistical
The discussion revolves around finding maximum likelihood estimators (MLEs) for parameters μ, σ, and τ from two independent normal distributions with different variances. The likelihood function is constructed as the product of the likelihoods from each sample, and the participants emphasize the importance of deriving these functions correctly. A simpler example using the exponential distribution is provided to illustrate the process of forming the likelihood function, taking the logarithm, and finding the MLE by setting the derivative to zero. The conversation highlights the need for clarity in the derivation steps, particularly for those struggling with the mathematical concepts involved. This guidance aims to build confidence in tackling similar statistical inference questions.
cmk1300
Hello, I am wondering if anyone would be able to guide me through a practice question for an upcoming test. I am not feeling very confident at this point and would very much appreciate some help!
The question is as follows;
Let {X}_{1},{X}_{2}…, {X}_{n}and {Y}_{1},{Y}_{2}…,{Y}_{m} be two independent random samples from N(μ, {σ}^{2}) and N(μ,{τ}^{2}) respectively, where the parameters 𝜇, σ,τ, are unknown with -∞< μ<∞, σ > 0 and τ > 0. Assume that {σ}^{2}≠{τ}^{2} and both are unknown. Find the maximum likelihood estimators of μ, σ and τ (Hint: the likelihood function is the product of [L(μ,{σ}^{2};{x}_{1},{x}_{2}…,{x}_{n})] and [L(μ ,{τ}^{2};{y}_{1},{y}_{2}…,{y}_{m}]
Thank you in advance!
As instructed by the hint you need the likelihood functions $\mathcal{L}(\mu, \sigma^2, x_1,\ldots,x_n)$ and $\mathcal{L}(\mu,\tau^2, y_1,\ldots,y_m)$. Can you derive those functions? For a normal distribution $\mathcal{N}(\mu,\sigma^2)$ the pdf is given by
$$f(x) = \frac{1}{\sigma \sqrt{2\pi}} \ \mbox{exp}\ \left\{ \frac{-1}{2} \left(\frac{x-\mu}{\sigma}\right)^2 \right\}$$
The derivation steps are the parts I struggle with the most... My professor does not exactly take the time to explain them either. Could you possibly guide me through this as well please?
Maybe it would be better to see how a simpler example works.
Try the exponential distribution whose pdf is f=(1/a)e^(-x/a)
Say you have 2 observations x_i=1,5
MLE is about estimating the parameter 'a' assuming that the observations actually happened.
What's the probability of those observations happening? It is fx_1*fx_2 which is then called the likelihood function L:
L(a)= [(1/a)e^(-1/a)] [(1/a)e^(-5/a)]
L(a)= (1/a)^2*e^(-(1+5)/a)
The next step is taking the log of the expression.
We do this because it is usually much easier to take partial derivatives with a function of + and - as opposed to * and /
l(a)= ln[(1/a)^2*e^(-(1+5)/a)]
l(a)= -2ln(a) -6/a
Then we take the derivative of l(a) with respect to 'a' (since this is the parameter we're estimating) and set the equation equal to 0 which is how we get the maximum of the function (from 1st year calculus)
0= -2/a + 6/a^2
a= 3
Try to see how L(a) would change if there were 3 observations or 10 or n.
Siron gave the pdf of a normal.
First figure out what L of n observations looks like.
Then multiply that with another L with n observations and a different shape parameter.
You'll estimate each of mu, sigma and t so once you have the loglikelihood function take the derivative with respect to each of these params and set to 0.
Hope this helps
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
