Help with a tan(arccos(z)) question
  • Thread starter JeremyEbert
In summary, tan(arccos(z)) relates to prime numbers and the harmonic series, Fourier transform and the inverse-square law. It also has a relation to roots of unity.
JeremyEbert
204
I need help describing the relationship of tan(arccos(z)) when z=(x-1)/(x+1) as the core piece of this equation here:
http://3.bp.blogspot.com/-5UhMF-uGw...AFQ/oDdl_oSXPM0/s1600/prime-+squares+edit.png
and here notice the square root of pimes x, hoizontal vector towards the y axis. You may have to zoom in:
http://2.bp.blogspot.com/_u6-6d4_gs...AAAE8/_hov_b0sno4/s1600/prime-+square+12a.png
Now in iy, right?
http://upload.wikimedia.org/wikiped...mental_relationship_to_Circle_(and_Helix).gif
and its relation ship to roots of unity:
http://www.katjaas.nl/rootsofunity/rootsofunity.html
root systems:
http://en.wikipedia.org/wiki/Root_system
Does it have a relation to “(x-1)/(x+1)^(-x/2) = e” as well?
Any help wood be greatly appreciated. Trying to teach myself…
Ok, I'm working on an animation of what I'm trying to equate. here is what I have so far:
http://i98.photobucket.com/albums/l267/alienearcandy/sqrt-1.gif
It seems to be related to the harmonic series, Fourier transform and the inverse-square law.
Is there already an equation that defines this animation?
Again it releates twards primes...
and
http://4.bp.blogspot.com/_u6-6d4_gs.../bdPIJMIFTLE/s1600/prime-+square+12a+zoom.png
I know you guys have to be sick of seeing these images...
I'm seeing these sequences in a triangular sequence related to angular momentum: t(n,m)=4*(n*(n-1)-m*(m-1)). :
http://oeis.org/A152420
I'm trying to put this in complex form as it relates to the roots of unity.
In this equation the root values lie on the y axis. I'm not using 2pi/n, so the radians intervals are not equal, infact they are releated to the complementary numbers of the base (x+1) where the roots are of the form tan(arccos((x-d)/(x+1))) where d eqauls intergers from 1 to x-1. I need help defining this root system.
[tex]tan(arccos(z)) = sin(arccos(z))/cos(arccos(z)) = \frac{\sqrt{1-z^2}}{z} = \frac{\sqrt{1-((x-1)/(x+1))^2}}{(x-1)/(x+1)} = \frac{\sqrt{(x+1)^2-(x-1)^2}}{x-1} = \frac{\sqrt{4x}}{x-1} = \frac{2\sqrt{x}}{x-1} [/tex]
with sign depending on the quadrant the angle z lies in.
Thanks so much Jarle! Now I need z=(x-n)/(x+1) where n={1,3,5...2x-1}. Its the core of the pattern here:
http://tubeglow.com/test/Fourier.html
and here:
Related to Help with a tan(arccos(z)) question
1. What is the formula for tan(arccos(z))?
The formula for tan(arccos(z)) is √(1-z²)/z.
2. How do you simplify tan(arccos(z))?
To simplify tan(arccos(z)), use the trigonometric identity tan(arccos(z)) = √(1-z²)/z. Then, simplify the expression using algebraic techniques.
3. What is the domain of tan(arccos(z))?
The domain of tan(arccos(z)) is -1 ≤ z ≤ 1.
4. How do you graph tan(arccos(z))?
To graph tan(arccos(z)), first graph the inverse cosine function, arccos(z). Then, use the reciprocal function, 1/z, to graph the tangent function.
5. How is tan(arccos(z)) used in real life?
Tan(arccos(z)) is used in real life in various applications such as navigation and engineering. For example, it can be used to calculate the angle of elevation or depression in a building or structure.
  • Linear and Abstract Algebra
