Help with a vector proof about perpedndicular unit vectors
In summary, the vector b(t) is perpendicular to a(t) if and only if the following two conditions are met: 1) a(t) is a unit vector and 2) the components of b(t) are functions of t.
vande060
186
Prove that if a(t) is a unit vector whose components are functions of t, then the vector b(t) = da(t)/dt is perpendicular to a(t)
here i have the parameters that make a(t) a unit vector:
1 = f(t)^2 + g(t)^2
i know of the example sinxi + cosxj = a(t)
but that is the only one i can get to work. I need a general proof though so:
a(t) = f(t)^2 i + g(t)^2 j
b(t) = f '(t) i + g '(t) j
(dot) product of a(t) and b(t) is:
f(t)*f '(t) + g(t)*g '(t)
i tried to take the derivative of a(t) and solve for both f'(t) and g'(t)
1 = f(t)^2 + g(t)^2
0 = 2*f(t)*f'(t) + 2*g(t)*g'(t)
i treated this like one big equation and solved each for g'(t) and f'(t)
f ' (t) = [-g(t)*g ' (t)]/ f(t)
g ' (t) = [-f(t)*f ' (t)]/ g(t)
when i carry out the dot product i still don't get zero, i need some advice, am i even on the right track.
the only other way i could think of was to setting each component equal to zero to solve for the derivative of the functions, but i did not know if this was mathematically legal
ex:
2*g(t)*g'(t) = 0
g'(t) = 0
1 = f(t)^2 + g(t)^2
Use this expression to express g(t) in terms of f(t). That will help greatly.
I don't understand the part in red. Why have you squared the functions? They should not be squared if your definition of a is to be consistent with your definition of b. The rest of what you have doesn't make sense either. See if following my advice above helps.
did you mean this one: 1 = f(t)^2 + g(t)^2
so f(t) = (1 - g(t)^2)^1/2
and g(t) = (1- f(t)^2)^1/2
then the derivative of the above:
f ' (t) = -[g(t)*g ' (t)] / [1-g(t)^2]
g ' (t) = -[f(t)*f ' (t)] / [1-f(t)^2]
so then if i take the dot product
[f(t) * f ' (t)] + [ g(t) * g ' (t) ]
(1 - g(t)^2)^1/2 * -[g(t)*g ' (t)] / [1-g(t)^2] + (1- f(t)^2)^1/2 * -[f(t)*f ' (t)] / [1-f(t)^2]
simplified :
-[g(t)*g ' (t)] -[f(t)*f ' (t)]
still don't understand it, where is my error?? :confused:
Yes.
You just need one of these. The whole point is to eliminate one by expressing it in terms of the other. For example, if you express g in terms of f, then henceforth everything is in terms of f and you don't need g anymore. Do you understand?
Here is the problem. This differentiation is wrong. You need to use the chain rule since:
dg/dt = dg/df * df/dt
What is g(f), and what is its derivative with respect to f? That is the first step. The second step is to multiply that by df/dt.
Also, again, you only have to compute ONE of the above derivatives.
got it finished, thanks. i wasnt thinking of eliminating terms correctly, like you said
FAQ: Help with a vector proof about perpedndicular unit vectors
1. What is a vector proof?
A vector proof is a mathematical method of demonstrating that a set of vectors follow a certain property or relationship, using logical reasoning and mathematical operations.
2. What is a perpendicular unit vector?
A perpendicular unit vector is a vector that is perpendicular (at a right angle) to another vector, and has a magnitude of 1. This means that it points in a direction that is 90 degrees from the original vector, and has a length of 1 unit.
3. How do you prove that two vectors are perpendicular?
To prove that two vectors are perpendicular, you can use the dot product. If the dot product of two vectors is equal to 0, then they are perpendicular. This is because the dot product takes into account the angle between the two vectors, and if they are perpendicular, the angle will be 90 degrees and the dot product will be 0.
4. What does the term "unit vector" mean?
A unit vector is a vector that has a magnitude of 1. It is often used in mathematics to represent a direction without taking into account the length or size of the vector. Unit vectors are useful because they can be scaled to any length without changing the direction they are pointing in.
5. Why is it important to use unit vectors in a proof?
Using unit vectors in a proof can make the calculations and reasoning simpler and more concise. Additionally, unit vectors allow us to focus on the direction of a vector rather than its magnitude, which can be helpful in certain mathematical applications.
