jcranford
- 2
Consider the ideal Atwood's machine in Figure 4-65. When N washers are transferred from the left side to the right side, the right side descends 47.1cm in 0.40s. Find N.
a = (m2-m1/m1+m2)g
I'm honestly not sure where to start with this one. We did one Atwood example in class and it wasn't anything like this. I'm not sure if that equation is relevant either, it's just the one that was given when we did the example in class.
The first thing I did was convert the given distance and time into an acceleration of m/s2, so I converted the 47.1cm -> .471m / .4s and got 1.17m/s, then divided by .4s again to get 2.94m/s2, which I'm not sure if that's the right way to do that or not. I think I have to solve for the masses, but I'm just really lost without a clue on this one. A push in the right direction would be greatly appreciated.Also, if anyone wants to take a look at this one while they're at it. This is what I've done so far.
For (a), I basically found the max force of static friction and said that was the most horizontal force it could have exerted on it for the top block not to slip. (b), I used the net force it gave me to calculate m(a) for 1.5m/s2 and then calculated the force of friction by subtracting the net force of the smaller block from static friction for the smaller block. I'm not really sure that's a legal maneuver. I'm just lost on (c). At first I just used the new force to calculate an acceleration, but then I realized they would have two different accelerations due to this force being greater than the max static friction force. It's probably because it's late but I'm just blanking on what I'm supposed to do next. Any suggestions would be great. Thank you all.
