Help with an integral, yet again.
  • Thread starter DrKareem
  • Tags
    Integral
In summary, the integral being solved is \int \frac{1}{1+\sin^2{\theta}}d\theta from 0 to pi, which is equivalent to half the same integral over the unit circle. The integral is transformed using trigonometric substitution and expressed in the form \frac{1}{i} \int \frac{z}{-z^4+z^2-1} dz. The poles are identified to be on the contour path and the residue theorem is mentioned as a possible method to solve it. However, the conversation shifts to using a different method and substituting to cos(2x). The suggestion is made to substitute z=e^{2 i \theta} to simplify the integral and use the
DrKareem
101
Hi, the integral I'm trying to solve is:
[tex] \int \frac{1}{1+\sin^2{\theta}}d\theta [/tex]
From 0 to pi, which is the same as half the same integral over the unit circle.
I changed the sine squared into 1-cos[2x] and then expressed cos[2x] as half z^2 +(z-1)^2 and i finally got it in this form:
[tex] \frac{1}{i} \int \frac{z}{-z^4+z^2-1} dz [/tex]
I found out the poles to be -1/2 +- i sqrt(3)/2 which happen to be on the countour path, and in that case i don't know how to apply the residue theorem, if it could be applied that is.
Edit: The answer is given in the book to be pi/sqrt(2)
Let sin(x)=u and express the entire integral in terms of u. the denominator is just 1+u^2, and solve and sub to dtheta to du, we get
[tex]\int \frac{\sqrt{1-u^2}}{1+u^2} du[/tex]. Trig sub.
Ahh nvm my last post..I must have done something wrong because when you check it on www.calc101.com it dusnt gimme the same thing...But I don't undersatnd how you textbook gives you a constant for an indefinite integral..
BTW: The answer isn't nice..
Your textbook is correct if this is pi:
Okay I see where you're going here, it should be solved using that method. However, i took the integral from a chapter on the residue method in integration. So I'm trying to solve it using that method, and explained how i got stuck.
I have no idea what the theorem is :D
Edit: Method, not theorem
your sub to cos(2x) is fine, and then exp's. what you then want to do is substitute [tex] z=e^{2 i \theta} thus dz=2i z d\theta [/tex]. Your substitution was a little funky. thus [tex]cos(2 \theta) = \frac{z+ (1/z)}{2} [/tex].
youll get a slightly easier integral which you can just take the residue of for the answer
Oh my God that was so trivial. Thanks for the help guys.
Edit: Actually it IS the residue THEOREM not method :P
cool problem, shows the awesome power of the residue theorem!
Yes awesome indeed. I just started studying this and it looks really nice, although some aspects of it are hard to grasp. I guess i should be practicing even more...
Practice makes permanant!
FAQ: Help with an integral, yet again.
What is an integral?
An integral is a mathematical concept used to find the area under a curve or the accumulation of a function over a given interval. It is represented by the symbol ∫ and is used in calculus to solve problems related to rates of change and accumulation.
How do I solve an integral?
To solve an integral, you can use various methods such as substitution, integration by parts, or the fundamental theorem of calculus. It is important to identify the type of integral and apply the appropriate method to solve it. You can also use online integral calculators or software to solve complicated integrals.
What are the applications of integrals?
Integrals have various applications in mathematics, physics, engineering, and other fields. They are used to calculate areas, volumes, work done, and other physical quantities. In economics, integrals are used to find total revenue and profit. They are also used in signal processing, probability, and statistics.
What are the common mistakes made when solving integrals?
One of the common mistakes made when solving integrals is forgetting to add the constant of integration. This can lead to incorrect solutions. Another mistake is not simplifying the integrand before integrating, which can make the problem more complicated. It is also important to check the limits of integration and ensure they are correct.
How can I improve my skills in solving integrals?
Practice is key to improving your skills in solving integrals. Start with simple integrals and gradually move on to more complex ones. It is also helpful to understand the concepts behind integration and the different methods used to solve integrals. Consulting with a tutor or joining a study group can also help improve your skills.
