Help with carbon dating question please
  • Thread starter cd95
  • Tags
    Carbon
In summary, the question is asking for the number of disintegrations occurring in 1 mole of carbon-14 atoms from a living organism. The number of carbon-14 atoms for each atom of carbon-12 in living materials is 1.3x10^-12, and the half-life of carbon-14 is 5730 years. After working out the equation Kb=ln2/(1.80x10^11) seconds, the number of disintegrations per second is calculated to be 3.85x10^-12. Multiplying this by the number of carbon-14 atoms gives the answer of 5.97x10^-23, which is incorrect. It is important to note that one mole of a
cd95
desperately need help with the question below. me and my dad have been working on it for hours but keep getting the answer to be 5.97x10^-23?! totally off what it should be.
Q. There are about 1.3x10^-12 carbon-14 atoms for each atom of carbon-12 in living materials, and the half-life of carbon-14 is 5730 years. Show that the number of disintegrations occurring in 1 mole of carbon from a living organism is 2.3 per second.
Thanks
Charley
Show what you and your dad have done so far. What do you know about radioactive decay? What is half-life?
ehild
this is what we worked out...
(1.3x10^-12) x 12 = 1.56x10^-11 gm C14/gm C
then using the equation Kb=ln2/half-life...
Kb=ln2/(1.80x10^11) seconds = 3.85x10^-12 disintegrations per second
Then...
(3.85x10^-12) x (1.56x10^-11) = 5.97x10^-23
what have we missed?
How many atoms are in one mole of a substance? Remember, it is the number of disintegrations of individual atoms that you are looking for.
Hello Charley,
I understand your frustration with this question, but let's break it down step by step to see where the error may be occurring.
First, let's remember that carbon-14 is a radioactive isotope of carbon that decays over time. This decay process is measured using the concept of half-life, which is the amount of time it takes for half of the original amount of a substance to decay.
In this question, we are given the information that there are 1.3x10^-12 carbon-14 atoms for each atom of carbon-12 in living materials. This means that for every 1.3x10^-12 grams of carbon-12 in a living organism, there is also 1.3x10^-12 grams of carbon-14. This ratio remains constant in living organisms.
Next, we are told that the half-life of carbon-14 is 5730 years. This means that after 5730 years, half of the original amount of carbon-14 will have decayed. After another 5730 years, half of that remaining amount will have decayed, and so on.
Now, to find the number of disintegrations occurring in 1 mole of carbon from a living organism, we need to use the Avogadro's number, which is 6.022x10^23. This number represents the number of particles (atoms or molecules) in one mole of a substance.
To find the number of disintegrations, we can use the formula N = N0 * (1/2)^(t/T), where N is the current number of atoms, N0 is the original number of atoms, t is the time, and T is the half-life.
Plugging in the given values, we get:
N = (1.3x10^-12 * 6.022x10^23) * (1/2)^(1/5730)
N = 7.84x10^11 * (1/2)^0.000114
N = 7.84x10^11 * 0.999886
N = 7.839x10^11
This means that for every mole of carbon in a living organism, there are approximately 7.839x10^11 disintegrations occurring per second.
I hope this explanation helps and clears up any confusion. Keep up the good work with your dad! Science can be challenging, but
FAQ: Help with carbon dating question please
What is carbon dating?
Carbon dating is a scientific method used to determine the age of organic materials. It is based on the decay rate of carbon-14, a radioactive isotope of carbon, which is present in all living organisms.
How does carbon dating work?
Carbon-14 is formed in the upper atmosphere through the interaction of cosmic rays with nitrogen atoms. This carbon-14 is then absorbed by living organisms through photosynthesis or consumption of other organisms. When an organism dies, it stops taking in carbon-14 and the existing carbon-14 begins to decay at a known rate. By measuring the amount of carbon-14 remaining in a sample, scientists can determine the age of the organism or material.
What are the limitations of carbon dating?
Carbon dating can only be used to date organic materials, as it relies on the presence of carbon-14. It is also limited to dating materials that are less than 50,000 years old, as the amount of carbon-14 becomes too small to accurately measure after that time. Additionally, environmental factors such as contamination and changes in the Earth's magnetic field can affect the accuracy of carbon dating.
What is the margin of error in carbon dating?
The margin of error in carbon dating can vary depending on the sample being tested and the method used. In general, the margin of error for carbon dating is around +/- 50-100 years. However, with advanced techniques and calibration, the margin of error can be reduced to +/- 20-30 years.
Can carbon dating be used to date all materials?
No, carbon dating can only be used to date organic materials. Inorganic materials, such as rocks or minerals, cannot be dated using carbon dating. Additionally, carbon dating is not always the most accurate method for dating materials, and other techniques such as dendrochronology (tree-ring dating) may be more appropriate in certain situations.
