Help with center of mass question
In summary: I see, so that simplifies the final answer to (ln2)/A. Thank you very much for taking the time to answer my question in detail, I really appreciate it.In summary, the conversation discusses solving a problem involving integrals, specifically ∫xtan(x^2)dx and ∫tan(x^2)dx, to find the values of My and M. The conversation also clarifies the correct integration process and the use of logarithmic rules. The final answer is (ln2)/A, where A represents the area.
student93
85
The problem is attached in this post.
x=My/M=(∫xf(x)dx)/(∫f(x)dx) from a to b
My=4∫xtan(x^2)dx from 0 to √π/2 = 2ln(2/√2)
M=4∫tan(x^2)dx from 0 to √π/2 =2xln(2/√2)
My/M= 2ln(2√2)/2xln(2/√2) = 1/x or 1/A
The answer however is (1/A)ln2
Wrong.
You have calculated the area but ∫xdm or 'My' (as you have put it) is
[itex] σ*∫xf(x)dx [/itex] {σ = Mass per unit Area}
[itex]∴ My = σ*2ln√2
[/itex]
Wrong.
First of all, you have calculated the area incorrectly. This integration is different from the previous one- there is no 'x' over here.
Moreover,
M = ∫dm = ∫σdA (Where σ= Mass per unit Area)=σ*Area.
Hope you got it!
Adithyan.
For "My", I'm still getting -2ln(√2/2) as the value of my integral. How did you get 2ln√2? Could you please clarify how you did the integration etc.?
[itex] -2ln(√2/2) = -2ln(1/√2) = -2ln(√2^{-1}) = (-2)*(-1)ln(√2)= 2ln√2. [/itex]
I guess, you are okay with my answer now. By the way, I did the first integration (ie [itex] ∫xtan(x^{2})dx [/itex]) by putting [itex] x^{2} = t[/itex]. (I hope you are well versed with integration by substitution.)
Yeah I also used substitution, also could you also please clarify the integration for "M", I keep getting -2xln(√2/2), which is equal to 2xln(ln√2) (Is this correct?). Also what exactly do I do with the "x" in my answer? (I got the "x" because I used substitution to solve for this integral).
Also the answer to the question is (ln2)/A, where "A" is equal to Area, however I don't know how to apply the variable "A" in regards to this question.
Let
[itex]
σ =\frac{Mass}{Area }. [/itex]
[itex]
M = σ*A
[/itex]
[itex]
∴dm = σdA
[/itex]
[itex]
M = ∫dm = ∫σdA =σ∫dA = σ*A
[/itex]
Here [itex]
A =∫f(x)dx = ∫tan(x^{2})dx [/itex]
and in this integration you cannot use substitution method since, there is no xdx term in it.
Is it possible to integrate 4tan(x^2) then? How exactly do you go about integrating a function such as 4tan(x^2) etc.?
I tried some of the common methods of integration, but they get messy later on. I don't think I can integrate this term at my current level of understanding of integration. Moreover, the question didn't ask for the value, they themselves substituted the value of this integral with A.
Ok that makes sense since I also had a lot of trouble trying to integrate 4tan(x^2).
Also after following the steps you provided, I ended up getting my answer to be (2ln2)/A instead of the actual answer (ln2)/A
I set x=My/M=((p)(2ln2))/((p)(A))
My=(p)(2ln2)
M=(p)(A)
p=density
A=Area
Did I make an error in my setup?
My=(p)(2ln2)
M=(p)(A)
p=density
A=Area
My=(p)(2ln2)
You made an error here.
You should get this term after integration: [itex] 2∫^{\frac{√\pi}{2}}_{0}ln(sec(x^{2})) [/itex]
I don't understand how you got that as the integral, after substitution, don't the limits of integration become π/4 and 0?
My=(p)4∫xtan(x^2)dx from 0 to √π/2
u=x^2 -> 0 to π/4 become the new limits of integration
du=2xdx
My=(p)(4/2)∫tan(u)du from 0 to π/4
My=(p)(2)(-ln(cos(u)) from 0 to π/4
My=(p)((-2ln(√2/2)-(-2ln(1))
My=(p)(-2ln(√2/2))=2ln(2)
du=2xdx
I think you need to get your logarithmic knowledge correct.
[itex] -2(ln(√2/2)) = -2(ln(\frac{1}{√2}) = 2ln(√2)= ln(√2^{2}) = ln(2) [/itex]
Here, go through these rules and learn them to avoid such calculation errors in future.
http://en.wikipedia.org/wiki/List_of_logarithmic_identities
FAQ: Help with center of mass question
1. What is the center of mass and why is it important?
The center of mass is a point within an object or system that represents the average location of all the mass in that object or system. It is important because it can help determine the stability and motion of an object, as well as the effects of external forces on that object.
2. How do you calculate the center of mass?
The center of mass can be calculated by finding the weighted average of the positions of all the individual masses in the object or system. This can be done by multiplying the mass of each component by its distance from a chosen reference point, and then dividing the sum of these products by the total mass of the object or system.
3. Can the center of mass be outside of the object?
Yes, the center of mass can be outside of the object if the object has an irregular shape or distribution of mass. This means that the object will not balance at its geometric center, but rather at the center of mass.
4. How does the center of mass change if an object is in motion?
The center of mass of an object does not change if the object is in motion unless an external force acts on the object. In this case, the center of mass may shift in the direction of the applied force.
5. How does the center of mass affect stability?
The location of the center of mass affects the stability of an object. If the center of mass is located above the base of support, the object will be stable. However, if the center of mass is outside of the base of support, the object will be unstable and may topple over.
