Help with Centripetal Force question
In summary: It's the method that matters.In summary, a 1000 kg sports car moving at 20 m/s crosses the rounded top of a hill with a radius of 100m. The normal force on the car is -6000 N, and the normal force on the 70 kg driver is -420 N. To find the car speed at which the normal force is zero, the acceleration from gravity and centripetal force must cancel each other out, resulting in a required force of 10000 N and a speed of 31.62 m/s.
Sagekilla
A 1000 kg sports car moving at 20 m/s crosses the rounded top of a hill (radius = 100m). Determine (a) the normal force on the car, (b) the normal force on the 70 kg driver, and (c) the car speed at which the normal force is zero.
F = ma
Fn = mg
[tex]a = v^2/r[/tex]
I solved for acceleration:
a = (20 m/s)^2 / 100 m = 4 m/s^2
I then solved for the centripetal force:
F = 1000 kg * 4 m/s^2 = 4000 N
New work:
I know the acceleration due to centripetal force is +4 m/s^2, and it points inwards towards the hill. Since gravity is -10 m/s^2, the total acceleration is -6 m/s^2 into the hill.
I tried using this to solve for the normal force:
Fn = 1000 kg * -6 m/s^2 = -6000 N
(a) Fn = -6000 N
I then solved for the normal force, Fnd, on the 70 kg driver:
Fnd = 70 kg * -6 m/s^2 = -420 N
(b) Fnd = -420 N
To find the speed the car would have to move for the normal force to become zero, I would need the acceleration from gravity and acceleration from the centripetal force to cancel each other out:
Fn = 1000 kg * 0 m/s^2 = 0 N
a = -10 m/s^2 + 10 m/s^2
I found the force required to accelerate at 10 m/s^2:
F = ma = 1000 kg * 10 m/s^2 = 10000 N
Then I derived the velocity according to the acceleration formula:
v = sqrt(a * r)
v = sqrt(10 m/s^2 * 100m) = 31.62 m/s
(c) v = 31.62 m/s
Does this look correct?
Looks fine to me. Most physics courses take gravity as 9.8 or 9.81 ms-2 but if you've been taking it as 10ms-2 then stick with that.
Yes, your approach and calculations are correct. To summarize:
(a) The normal force on the car is -6000 N.
(b) The normal force on the 70 kg driver is -420 N.
(c) The car speed at which the normal force is zero is 31.62 m/s.
FAQ: Help with Centripetal Force question
What is centripetal force?
Centripetal force is a force that acts towards the center of a circular motion, keeping an object moving in a curved path.
How do you calculate centripetal force?
Centripetal force can be calculated using the formula Fc = mv²/r, where Fc is the centripetal force, m is the mass of the object, v is the velocity, and r is the radius of the circular motion.
What is the difference between centripetal force and centrifugal force?
Centripetal force is the force that keeps an object moving in a circular path, while centrifugal force is the perceived outward force on an object due to its inertia.
How does centripetal force affect an object's motion?
Centripetal force causes an object to continuously change direction, keeping it moving in a circular path instead of a straight line.
What are some real-life examples of centripetal force?
Some common examples of centripetal force include the Earth's orbit around the sun, a car turning around a curve, and a satellite orbiting the Earth.
