Help with chi square distribution
In summary, the conversation discusses using moment generating functions to show that the sum of two chi square distributions with n and m degrees of freedom respectively, is a chi square distribution with n+m degrees of freedom. The process involves deriving the characteristic function from the MGF and starting with the Gaussian distribution.
sneaky666
66
How do i show that the a [X1 has a chi square distribution with n degrees of freedom] + [X2 has a chi square distribution with m degrees of freedom] is a [X1+X2 has a chi square distribution with n+m degrees of freedom]?
How can i use moment generating functions to do this?
Yes.
MX1=(1-2t)-n/2
MX2=(1-2t)-m/2
MX1+X2=MX1*MX1= (1-2t)-(n+m)/2
which is the MGF of a chi-square distribution with (n+m) degrees of freedom.
That's all I can come up with...not terribly good with this...
If you want to show that a given set of random variables has a chi square distribution and that these distributions are additive you need to start with the Gaussian and then derive the characteristic function from the MGF.
http://www.planetmathematics.com/CentralChiDistr.pdf
The chi square distribution is a commonly used statistical distribution in many scientific fields, including biology, psychology, and finance. It is often used to analyze categorical data and to test for the independence of two categorical variables.
To show that the sum of two chi square distributions with n and m degrees of freedom respectively, is a chi square distribution with n+m degrees of freedom, we can use the properties of moment generating functions. The moment generating function is a mathematical tool that allows us to calculate the moments of a distribution, including the mean, variance, and higher moments.
We know that the moment generating function of a chi square distribution with n degrees of freedom is given by M(t) = (1-2t)^(-n/2). Similarly, the moment generating function of a chi square distribution with m degrees of freedom is M(t) = (1-2t)^(-m/2).
Now, to show that the sum of two chi square distributions is also a chi square distribution, we can simply multiply their moment generating functions together. This results in M(t) = (1-2t)^(-(n+m)/2), which is the moment generating function of a chi square distribution with n+m degrees of freedom.
Therefore, we can conclude that the sum of two chi square distributions with n and m degrees of freedom respectively, is a chi square distribution with n+m degrees of freedom. This property can be very useful in statistical analysis, as it allows us to easily calculate the moments and other properties of the sum of multiple chi square distributions.
In summary, by using the properties of moment generating functions, we can show that the sum of two chi square distributions is also a chi square distribution, and that the degrees of freedom of the resulting distribution is the sum of the degrees of freedom of the individual distributions. I hope this explanation helps you better understand the chi square distribution and its properties.
Related to Help with chi square distribution
1. What is a chi square distribution?
A chi square distribution is a probability distribution that is used to analyze categorical data and determine whether there is a significant difference between expected and observed values. It is often used in hypothesis testing and is characterized by a non-negative and skewed shape.
2. How is the chi square distribution calculated?
The chi square distribution is calculated by taking the sum of the squared differences between the observed and expected values, divided by the expected values. This calculation results in a value that can then be compared to a critical value from a chi square table to determine the significance of the results.
3. What is the purpose of using a chi square distribution?
The chi square distribution is used to determine whether there is a significant difference between observed and expected values. This is important in research and scientific studies to determine if there is a relationship between variables or if the results are due to chance.
4. How do you interpret the results of a chi square test?
The results of a chi square test are interpreted by comparing the calculated chi square value to the critical value from a chi square table. If the calculated value is greater than the critical value, it is considered statistically significant and there is a significant difference between the observed and expected values. If the calculated value is less than the critical value, it is not considered statistically significant and there is no significant difference between the observed and expected values.
5. What are the assumptions of using a chi square distribution?
The assumptions of using a chi square distribution include having independent observations, having a sufficient sample size, and having expected values greater than 5 for each category. If these assumptions are not met, the results of the chi square test may not be accurate and alternative statistical tests may need to be used.
