Help with computing density of one variable change.
In summary, the density function fy(y) for Y is 3y^4 for y>1 and 0 for y<=1. The distribution function can be found by using the definition of Y and the distribution of X.
sneaky666
66
Let X have density function fx(x)=1/x^2 for x>1, otherwise fx(x)=0.
Let Y=X^(1/3). Compute the density function fy(y) for Y.
my attempt
P(X<=1)=0
P(Y^3<=1)=P(Y<=1)=0
P(1<x<inf)=P(1<Y^3<inf)
=1-P(Y<1)
i am stuck here.
The answer to this is
fy(y) = 3y^4 for y>1 and 0 for y<= 1
hi sneaky666! :smile:
(try using the X2 and X2 icons just above the Reply box :wink:)
No, that answer is wrong: ∫1 3y4 dy = ∞, and it should be 1. :wink:
If you want the distribution function begin looking at
[tex]
F(y) = P(Y \le y)
[/tex]
and use the definition of [tex] Y [/tex] to get this into a form that involves the distribution of [tex] X [/tex].
Related to Help with computing density of one variable change.
1. How do I compute the density of a single variable change?
To compute the density of a single variable change, you will need to know the mass and volume of the substance. The formula for density is density = mass/volume. Simply divide the mass by the volume to get the density value.
2. What units should I use when computing density?
The units for density can vary depending on the substance and the system of measurement being used. However, the most commonly used units for density are grams per cubic centimeter (g/cm3) or kilograms per cubic meter (kg/m3).
3. Can density be negative?
No, density cannot be negative. Density is a measure of how tightly packed the molecules of a substance are, and therefore it cannot have a negative value. If you get a negative value when computing density, it is likely due to an error in your measurements or calculations.
4. How is density related to mass and volume?
Density is directly related to mass and volume. As the mass of a substance increases, its density also increases. However, as the volume of a substance increases, its density decreases. This means that a substance with a higher density will be more compact and have a greater mass compared to a substance with a lower density.
5. Can density change with temperature?
Yes, density can change with temperature. This is because as temperature increases, the molecules of a substance become more energetic and tend to spread out, resulting in a decrease in density. On the other hand, as temperature decreases, the molecules move closer together, leading to an increase in density. This is why it is important to specify the temperature when reporting the density of a substance.
