Arv
- 6
Hi
I am not able to reason my way through conservation of energy
when I consider the following scenario..
Suppose you are holding up a weight and there is no movement of the
weight. According to theory this means no work is done on the weight
since net forces on it cancel and there is no movement. However it takes effort to hold it up and eventually you get tired which means that you are using up chemical energy to hold up the weight. So if no work is done which
means there is no energy transfer and yet chemical energy is being
used up to hold the weight (since you are getting tired)...where
does this chemical energy transfer to? It's not surely vanishing
or dissappearing as heat...
my imagination rather than reason says, its supplying the brick's
potential energy which is being 'sucked' away by the force exerted on
it by the earth..so energy being transferred to earth??...this seems
totally wrong but I can't seem to reason here...please help
Arvind
Arvind
