Help with differential operators
In summary: If l2 operates on a function, f(x), you will have:L_2 f=\frac{df}{dx}-fAs you can see from the above, the L_1L_2 f will be:L_1L_2 f=\frac{d}{dx}\left (\frac{df}{dx}-f\right )+2\left (\frac{df}{dx}-f\right )You can simplify this further to get the result: \frac{d^2f}{dx^2}+2\frac{df}{dx}-2f, which matches the result you have already gotten.
joker_900
64
This is a problem about differential operators, but I don't really get the notation used. I have L1 = (d/dx + 2) and L2 = (d/dx - 1)
Find L1(xe^-2x)
Show that L1L2 = L2L1 and find L1L2 in terms of d/dx, d2/dx2, etc.
So i thought that L1 = (d/dx + 2) means L1(f) = (df/dx + 2), so
L1(xe^-2x) = -2xe^-2x + e^-2x + 2
And so L1L2 is just L1 acting on L2 (or L1L2(f) is just performing L2 on f and then performing L1 on that result) and so L1L2 is just the differential of L2 plus 2
L1L2 = d2/dx2 + 2
But by that logic, L2L1 = d2/dx2 - 1
So what's wrong
Thanks
No, actually it means that
L1(f) = (d/dx + 2) f = df/dx + 2f.
In particular, you see that you should read a constant c as that constant times the zeroth derivative (= the function).
so
almost,
L1(xe^-2x) = -2xe^-2x + e^-2x + 2 x e^-2x (= e^-2x).
You better always act them on a test function and then throw that away afterwards. So for example, L1 L2 can be found by working out
L1 L2 f = (d/dx + 2) (d/dx - 1) f = (d/dx + 2) (df/dx - f) = (d2f/dx2 - df/dx + 2 df/dx - 2 f)
hence
L1 L2 = d2/dx2 - d/dx + 2 d/dx - 2,
and similarly for L2 L1 (didn't check for errors, you'll find out soon enough if I did it right :smile:)
If l1 operates on a function, f(x), you will have:
[tex]L_1 f=\frac{df}{dx}+2f [/tex]
FAQ: Help with differential operators
What are differential operators?
Differential operators are mathematical operators that are used to describe the rate of change of a function with respect to one or more independent variables. They are commonly used in calculus and are used to solve differential equations.
What is the difference between a differential operator and a derivative?
A differential operator is a mathematical notation that represents a derivative, while a derivative is a function that describes the rate of change of a function. In other words, a differential operator is a symbol that stands for a derivative.
How do you solve problems involving differential operators?
The first step in solving a problem involving differential operators is to identify the operator being used and the function it is acting on. Then, use the properties and rules of differential operators to simplify the expression. Finally, solve for the unknown variable or function using algebraic or numerical methods.
Can differential operators be used in real-world applications?
Yes, differential operators are used in a variety of fields, including physics, engineering, and economics. They can be used to model and solve real-world problems, such as determining the velocity of an object, predicting stock prices, or analyzing population growth.
Are there different types of differential operators?
Yes, there are several types of differential operators, including the derivative, gradient, divergence, and curl. Each type has its own properties and applications, and they are commonly used in different areas of mathematics and science.
