MHB Help with dividing an exponent
  • Thread starter Thread starter Sudharaka
    Exponent
Dividing exponents involves subtracting the exponent in the denominator from the exponent in the numerator when the bases are the same. In the case of 5x^2/10x^-5, the correct simplification leads to 1/2x^7, confirming MDS1005's initial understanding. The confusion arose from the addition of the coefficients 5 and 10, which must be simplified separately. Proper use of grouping symbols is emphasized to clarify the order of operations. Overall, MDS1005 is correct in their calculations and has found a supportive forum for future questions.
Sudharaka
MHB
MDS1005's question from Math Help Forum,
I'll keep this short. My understanding is dividing an exponent works as follows:
x^2/x^-5=x^7
The exponent rules state that you subtract the exponent in the denominator from the exponent in the numerator if they have the same base. 2 - (-5) = 7
Now, my question. Maybe I'm wrong, or maybe the answer I am looking at is wrong. I need to know which.
5x^2/10x^-5
My answer: 1/2x^7
Answer I was given: .5/x^5
The same source which provided this answer confirms my first idea of x^2/x^-5 = x^7. What changes when 5/10 is added onto the whole deal?
Hi MDS1005,
I hope you meant, that your answer is, \(\dfrac{1}{2}x^7\). If that is the case, your answer is correct and the given answer is wrong.\[\frac{5x^{2}}{10x^{-5}}=\frac{1}{2}x^{2-(-5)}=\frac{1}{2}x^7\]
Mathematics news on Phys.org
Thanks. I knew that I was correct. I actually lost a half hour of sleep last night trying to figure out how the answer I was given could possibly be correct (Wondering). And now, thanks to your recommendation I now have a new forum to ask me questions in. Thanks for that Sudharaka. I'm sure I'll have many many more questions to come, seeing as I just registered for school as a physics major and still have questions like this. Physics is going to be quite an undertaking after 10 years of not doing any math in a formal setting.
MDS1005,
you must use grouping symbols because of the Order of Operations.So, then you would have:
5x^2/(10x^-5)Better:
(5x^2)/(10x^-5)
Or, as:
5x^2/(10x^{-2})
Or, better:
(5x^2)/(10x^{-2})
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
