Help with Factor Of Safety (FOS) in Bolt Shear problem
In summary, the problem involves determining the maximum factor of safety for a bolt in single shear that is tightened to exert a tension force of 60 kN, with a diameter of 25 mm and a shear loading of 40 kN. The maximum tensile stress for the material of the bolt is 350 N/mm2 and the maximum shear stress is 60% of the maximum tensile stress. The formula for determining factor of safety is given, but the exact calculation is not clear. The solution involves determining the maximum tensile force for the bolt, which can be found by dividing the maximum tensile stress by the area of the bolt. This area can be found using the diameter of the bolt. Once
Jonathan Green
A Bolt is in single shear and is tightened so that it exerts a tension force of 60kN, the diameter of the bolt is 25mm and the shear loading is 40kN; Given that the tensile stress should not exceed 350N/mm2 and the maximum shear stress should be taken as 60% of the maximum tensile stress. Determine the maximum factor of safety for the above working condition and discuss the effect of using this value in a safety critical application.
I know FOS = Failure Load / Allowable Load but I am unsure how to work this out from the data.
Got as far as finding out the maximum shear stress is 210N/mm
Hello Jonathan, :welcome:
I'm not an expert in this area, but I'm pretty good at physics exercises.
I suppose your 210 comes from 350 times 0.6 but how you change the dimension from N/mm2 to N/mm is a mystery to me.
And: I notice you do not make use of the given 25 mm2; do you have a reason to assume that is not essential for this exercise ?
Make a plan to come to this safety factor and post it. In general: post detailed working so we don't have to suppose anything :smile: and make wrong assumptions
I am clueless. Yeah it should've been N/mm2. How do you think it should be worked out ?
Now all we need is that plan of yours. It doesn't help you if I do the exercise for you. My hint was meant to put you on a track:
determine which of the two has the smallest(*) safety factor, then for that one:
starting from the far end:
safety factor = max shear / actual shear
max shear = factor x max tensile
for the latter you have to invent a recipe (it's fairly straightforward)
(*) I must admit I do not understand the terminology 'determine the max factor of safety' in the problem statement: if it can easily stand the tension with a safety factor of 10 but not the shear with a safety factor of 0.99, then it breaks !
[edit] oh, and 'clueless' doesn't go well in the PF culture :rolleyes:
I appreciate this, but it helps the most if I can see it worked out fully. This is not for an assignment I am just having trouble thinking of the calculation. I have been trying at it all week.
What's the maximum tensile force for this bolt, given the maximum tensile stress ?
60Kn?
No, 60 kN (small k, big N) is the actual tensile force. If the maximum would be 60, the safety factor would be one and that's not good at all !
So is it 40kN?
Are you guessing or are you joking ? If 40 kN is the maximum tensile force, then it can never exert 60 kN at all !
Im sorry but I don't understand how to work this out. Please would you explain it to me, then I may get it.
OK, will try:
You are given that the max tensile stress for the material of the bolt is 350 N/mm2. So a bolt with an area of 1 mm2 gives up when the tensile force is 350 N.
So: what is the max tensile force for your exercise's bolt ?
So would it be 350N/mm2 dived by 22mm to equal 14N?
Wouldn't you think that is a bit small ? Trial and error again ?
Dimensions to the rescue:
What do you get when you divide N/mm2 by mm2 ? N/mm4
If one mm2 can pull 350 N, then 10 mm2 can pull how much ?
3500N?
So would it be 7700N?
Do I hear 8800 ? Think before posting !
a) it was a 25 mm bolt, not a 22
b) 7700 = 350 N/mm2 x 22 mm gives you the wrong dimension of N/mm !
Yes sorry. 8800. So is 8800 the max tensile force for your exercise's bolt?
Aaargh... remember the first line in #17 !
-- And it's your exercise, not mine :smile:
You can NOT get Newtons if you multiply N/mm2 with mm .
Your answer in #15 was correct -- I hope you understand that. But your bolt is not 10 mm2 (its area). It is 25 mm diameter. What is the area of a bolt with a diameter of 25 mm ?
490?
pie R squared?
Do you want to continue until you guess the right answer ? If so, #20 is plain wrong and #21 is a lot better -- except for the question mark o0), that should have been an exclamation mark.
Now, do we continue this way or can you calculate the radius, area and max tensile force of a bolt with a diameter of 25 mm by yourself ?
[edit] Oops, I was too fast: #20 is only wrong because you left out the dimension (it is not 490 m2 but 490 mm2) -- the numerical value is OK.
All in good spirit, of course.:wink:
I don't appreciate you patronising me. I came here because I can't work this out. If your going to mock me, please don't reply.
OK. So 490 was correct then ?
490 mm2 to be precise ?
Likes BvU
My apologies. I am here because I like to help, but sometimes my ironic approach takes over. 490 mm2 is the area. 1 mm2 can pull 350 N, so how much can the bolt pull (tensile force) ?
is it 171500mm2?
490 mm2 x 350 N/mm2 = 172000 N ( not mm2 )
*171500N
Good. so the safety factor for the tension is ... ?
And the maximum shear force is ... ?
Which leads to:
The safety factor for the shtension is ... ?
Related to Help with Factor Of Safety (FOS) in Bolt Shear problem
What is Factor Of Safety (FOS) in Bolt Shear problem?
Factor Of Safety (FOS) in Bolt Shear problem is a measure of the safety margin in a bolted joint. It is the ratio of the maximum load that a bolt can withstand before failure to the actual load applied on the bolt. A higher FOS indicates a stronger and safer joint.
Why is Factor Of Safety (FOS) important in Bolt Shear problem?
Factor Of Safety (FOS) is important in Bolt Shear problem because it ensures that the bolted joint can withstand the applied load without failure. It also takes into account any uncertainties in the design, material properties, and external factors, providing an additional safety margin.
How is Factor Of Safety (FOS) calculated in Bolt Shear problem?
The Factor Of Safety (FOS) in Bolt Shear problem is calculated by dividing the maximum load the bolt can withstand by the actual load applied on the bolt. The maximum load can be determined using the bolt's material properties, diameter, and length, while the actual load can be calculated from the external forces acting on the joint.
What is the recommended Factor Of Safety (FOS) in Bolt Shear problem?
The recommended Factor Of Safety (FOS) in Bolt Shear problem varies depending on the application and industry standards. However, a common FOS range is between 1.5 to 3, indicating a safety margin of 50% to 200%. It is important to consult industry standards and guidelines to determine the appropriate FOS for a specific bolted joint.
How can I improve the Factor Of Safety (FOS) in Bolt Shear problem?
To improve the Factor Of Safety (FOS) in Bolt Shear problem, you can use bolts with higher strength and quality, increase the number of bolts in the joint, or use a larger bolt diameter. Additionally, proper installation techniques and regular maintenance can also help improve the FOS of a bolted joint.
9K
