Gozza
- 2
I am designing a kayak training machine as a final year project. Basically, the design consists of a frame supporting a weighted flywheel that provides the resistance. The flywheel is mounted on a shaft through bearing units in the frame and opposite direction sprag clutches are mounted onto pulleys and attached to the shaft. This enables drive motion to be applied to the flywheel with a freerunning motion in the reverse direction. Attached to these pulleys is a rope that runs to the paddle at one end, and a bungee cord at the other that will re-right the drive motion of the kayak stroke.
1. Essentially the problem is, how big a flywheel will I need to produce a force of 40N with each stroke. This is based upon a situation where stroke rate will be around the 82 strokes per minute area.
I am pretty clueless at what data is needed to solve the problem. I can find out more data if neccesary to solve it. If anyone could help me I would be greatly appreciative.
Thanks,
Gozza
Thanks,
Gozza
