Help with Friction and Stopping Car
In summary, on a horizontal surface, the car will stop at the minimum distance when the coefficient of static friction is .100 and the surface is dry. The car will stop at 255 meters when the coefficient of static friction is .600.
Husker70
90
A car is traveling at 50.0 mi/h on a horizontal highway. (a) If the coefficient of
static friction between road and tires on a rainy day is .100, what is the minimum
distance in which the car will stop? (b) What is the stopping distance when
the surface is dry and coefficient of static friction is .600?
2. Homework Equations [/]
I'm not sure how to get started as I don't know the normal force, and I'm not
sure what to solve for. If someone can help get the ball rolling I should be able
to finish. Any help would be appreciated.
Kevin
Hi Husker70! :smile:
Call the mass of the car m (it will cancel out later :wink:).
Then the normal force (on a horizontal surface) is just mg.
Now use F = ma to find the acceleration … which will be constant, so you can then use the usual uniform accleration kinetic equations. :smile:
Thanks for the start and I figured that the mass shouldn't matter but in order to
slove for the acceleration, I'm not sure how to find the force.
Thanks,
Kevin
Husker70 said:
… in order to
Hi Kevin! :smile:
Since it's a horizontal road, the only force slowing it down is the friction force …
so multiply the normal force by µ. :smile:
Does this seem right?
50 mi/h = 80.4672 km/h = 22.352 m/s
a= .100n
ma = .100(g)
a = .98
solving for time
v=vo + at
22.352m/s=0+.98(t)
t=22.81s
solving for distance
d=do+vot+at^2/2
d= 0+0+.98(22.815)^2/2
d= 255m
Thanks for everyone's help
Kevin
Hi Kevin! :smile:
Right answer, long-winded method …
a= .100n
ma = .100(g)
a = .98
a = .98 is right, but the other lines should be:
ma= .100n
a = .100(g) :wink:
solving for time
v=vo + at
22.352m/s=0+.98(t)
t=22.81s
d=do+vot+at^2/2
d= 255m
hmm … you have vf and vi and you need s but not t …
so it would have been a lot quicker just to use vf2 = vi2 + 2as :smile:
Hello,
I am working on the same problem, but I do not comprehend the work that was done to solve this problem.
Problem statement and variables given:
Q: A car is traveling 50.0 mi/h on a horizontal highway. (a.) If the coefficient of static friction between road and tires on a rainy day is 0.100, what is the minimum distance in which the car will stop? (b.) What is the stopping distance when the surface is dry and mu(s)=0.600? (mu(s) I think means static friction)
Attempt:
What I did was draw a free-body diagram where the weight force(earth is acting upon the car) is pointing down, normal force(road acting upon the car) is pointing up, and there is a friction force going to the left. I did convert 50.0mi/hr to 22.35m/s, but after that I am lost.
Thank you,
Joyce
Welcome to PF!
Hello, Joyce! Welcome to PF! :smile:
(have a mu: µ :wink:)
i] First, find the friction force.
ii] Then find the acceleration.
What do you get? :smile:
Hello Tiny-Tim,
Would the friction force be: F=-w+N (friction equals negative weight force plus normal force)? I think I might be confused on how to obtain the friction force.
Thank you,
Joyce Kuang
Hello Joyce! :smile:
That is a valid equation, but it's the equation for the net vertical force
in this case the vertical acceleration is zero,
so (from good ol' https://www.physicsforums.com/library.php?do=view_item&itemid=26") mass times 0 = net force = -W + N.
so W = N …
in other words, when something stays on a flat surface (so that its vertical acceleration is zero), then the normal force equals the weight. :smile:
(you can get a similar equation for the normal force on a slope, by doing 0 = net perpendicular force)
To get the https://www.physicsforums.com/library.php?do=view_item&itemid=39" force, you don't use F = ma at all, you use F = µN,
ie friction = µ times normal force
This works either for kinetic friction (µk), or for maximum static friction (µs) …
in this case, the static friction is maximum, since the question says so (because it asks for the minimum stopping distance). :wink:
Likes James Price
Hello,
What I have so far is:
Summation of F=m(0)=net force=-w+N
In which you said w=N
Then you said to use F=[itex]\mu[/itex] N
I know that [itex]\mu[/itex] is 0.100
so, F=(.100)N
What is N? I know that it is equal to the weight force, but it does not give me a value for the weight or normal force. How can I obtain that value?
And after finding the normal force, then I know the friction force, right?
After finding the friction force why do I have to find the acceleration? Is it because we need acceleration to find the minimum distance?
Thank you,
Joyce
Joyci116 said:
… I know that [itex]\mu[/itex] is 0.100
so, F=(.100)N
They don't give you the mass of the car, so call it "m" (it will cancel out later, when you find "a") …
then W = mg. :wink:
Yes, once you know "a", you can use one of the standard https://www.physicsforums.com/library.php?do=view_item&itemid=204" equations. :smile:
I'm so sorry, but I am still a little confused.
The normal force (N in Newtons) is equal to the weight force.
You said to use "m" to represent the mass, but what do I do after that?
What do I do with my F=[itex]\mu[/itex]N equation? How does that relate to the mass?
Maybe that is where my trouble lies. I do not see a connection between the mass and the equation, or I do not understand.
Thank you,
Joyce
Hey, Joyce.
You know that F=[itex]\mu[/itex]N. You also know that N = W = mg.
Now, gravity is simply an acceleration in the y-direction, correct?
So, now you know that N = ma[itex]_{y}[/itex]
You already knew that F=[itex]\mu[/itex]N. Now F, in this situation, is friction force. So, it is a force in the x-direction. So, given that, you could say that...
ma[itex]_{x}[/itex]=[itex]\mu[/itex]ma[itex]_{y}[/itex]
Since the mass is the same for both sides, the masses cancel out (since you would divide both sides by m). That leaves you with...
a[itex]_{x}[/itex]=[itex]\mu[/itex]a[itex]_{y}[/itex]
From that you can solve for a[itex]_{x}[/itex] and then use kinematics to solve for [itex]\Delta[/itex]x.
Enjoy,
Alex
Aggression200,
Thanks, I got it.
What I did was:
F=[itex]\mu[/itex]sN
N=mg
N-may (g is ay)
max=[itex]\mu[/itex]s(may)
a=(.100)(-9.8)= -0.98
Vi=22.35 m/s
Vf=0 m/s
x=?
So take the equation Vf2=Vi2 +2ax
Solved for x, which gives you
(Vf2-Vi2)/(2a)
x=255m?
Thank you very much,
Joyce
FAQ: Help with Friction and Stopping Car
How does friction affect a car's stopping distance?
Friction is the force that opposes motion between two surfaces in contact. When a car is in motion, the tires experience friction with the road surface, which helps to slow down the car. The higher the friction between the tires and the road, the shorter the stopping distance of the car.
What factors affect the amount of friction between a car's tires and the road?
The amount of friction between a car's tires and the road depends on several factors, including the type of tires, the condition of the road surface, the car's speed, and the weight of the car. For example, a car with worn-out tires will have less friction with the road, resulting in a longer stopping distance.
How can the type of tires affect a car's stopping distance?
The type of tires on a car can greatly impact its stopping distance. Tires with a larger surface area and deeper treads can provide more friction with the road, resulting in a shorter stopping distance. On the other hand, tires with less surface area and shallower treads may have less friction with the road, leading to a longer stopping distance.
How can I reduce the friction between my car's tires and the road?
To reduce the friction between your car's tires and the road, you can try reducing your speed, maintaining proper tire pressure, and using tires with a lower rolling resistance. However, it is important to note that reducing friction can also decrease the car's stability and control, so it is essential to find a balance for safe driving.
Can weather conditions affect a car's stopping distance due to friction?
Yes, weather conditions can significantly impact a car's stopping distance due to friction. For example, wet or icy roads can reduce the friction between the tires and the road, resulting in a longer stopping distance. It is important to adjust your driving speed and be extra cautious in adverse weather conditions to ensure safe stopping distances.
