Help with Friedman equations and density of energy
In summary, the author is trying to understand something about the Friedman equations and does not understand how the cosmol. constant and vacuum energy density works against gravitation. Differentiating the equation with respect to time shows that there is cosmological repulsion when pressure is sufficiently negative.
Helpsearcher
Hi there,
I really hope someone can help me with my stupid but urgent problem of understanding something crucial about the Friedman equations.
So; one of them looks like this (forget about the constants; it is about the principles):
change of the scale factor with time - density - cosmol. constant = -k (curvature term)
Then this is sometimes rewritten in terms of densities, which gives:
change of the scale factor with time - (density of matter + vacuum energy density) = -k (curvature term)
Now; here is what I do not get.
Generally the density of the vacuum (or equivalently the cosmol. constant) are treated just like the density of matter; so they have the same effect on the curvature, which somehow should be understandable as energy=matter and so both curve the spacetime.
But then, it is usually stated that the cosmol. constant, and so the vacuum energy density, are working against gravitation (repulsive).
However; I do not understand, how to see this in the equations above. I mean; both seem to have the same effect: energy=matter -> attraction (simplified).
Where is my error of thinking?
I really hope that someone here can enlighten me.
Thx
Space news on Phys.org
Cosmological gravitational repulsion means that ##\dot{a}##, the rate of change of the scale factor, is increasing. i.e., that ##\ddot{a}## is positive. The Friedmann equation about which you wrote is
$$\dot{a}^2 = \frac{8\pi}{3} \rho a^2.$$
Differentiating this equation with respect to time gives
$$2\dot{a}\ddot{a} = \frac{8\pi}{3} \left( \dot{\rho} a^2 +2\rho a \dot{a} \right).$$
Consequently, there is cosmological repulsion when ##0 < \dot{\rho} a^2 +2\rho a \dot{a}##.
It is somewhat difficult to see what is going on from this, but a couple of things can be noted:
1) in an expanding universe, there is no gravitational repulsion only when ##\dot{\rho} a^2## is sufficiently negative (as it is for normal matter);
2) for an expanding universe that consists solely of vacuum energy, which has ##\dot{\rho} = 0##, there is repulsion, since then ##\ddot{a} > 0##.
Things become a little clearer when the other Friedmann equation is considered,
$$\ddot{a} = -\frac{4\pi}{3} \left( \rho + 3p \right) R.$$
Clearly, ##\ddot{a} > 0## when ##w = p / \rho## is less than -1/3. Vacuum energy/cosmological constant has w = -1.
Roughly, (for non-exotic matter that has positive energy density) repulsion happens when pressure is sufficiently negative.
Hi;
thank you for the answers.
I totally missed (or have overseen) the second more important equation in this context (the second derivative), which shows the dependencies on the pressure terms.
Will have a deeper look into now that the examination is over. :) Was a little confused the day before.
Thx
FAQ: Help with Friedman equations and density of energy
What are the Friedman equations used for?
The Friedman equations, named after physicist Alexander Friedman, are used to describe the expansion and evolution of the universe. They are a set of equations in general relativity that relate the density of matter and energy in the universe to its rate of expansion.
How do the Friedman equations relate to the density of energy?
The Friedman equations include terms for both the density of matter and the density of energy in the universe. The density of energy, also known as the energy density, is a measure of the amount of energy per unit volume in the universe. It is a key factor in determining the overall dynamics and evolution of the universe.
How is the density of energy calculated?
The density of energy can be calculated using the energy-momentum tensor, which is a mathematical object that describes the flow of energy and momentum through space-time. This tensor includes contributions from all forms of energy, including matter, radiation, and dark energy.
What is the relationship between the density of energy and the expansion rate of the universe?
The density of energy directly affects the expansion rate of the universe through the Friedman equations. As the density of energy increases, the expansion rate of the universe also increases. Conversely, as the density of energy decreases, the expansion rate of the universe slows down.
How does dark energy impact the Friedman equations?
Dark energy, a mysterious form of energy that is thought to make up about 70% of the total energy in the universe, has a significant impact on the Friedman equations. Its presence is necessary to explain the observed accelerated expansion of the universe, and it appears as a term in the Friedman equations that contributes to the overall energy density of the universe.
