MHB Help with Geometry: Volume, Area and Perimeter of Pyramid
The discussion focuses on calculating the perimeter, volume, and surface area of a pyramid with a square base and slanted edges, all measuring 5 cm. The perimeter is determined to be 40 cm, while the surface area combines the area of the base (25 cm²) and the area of four equilateral triangles (25√3 cm²), resulting in a total surface area of (25√3 + 25) cm². The volume is calculated using the formula for a pyramid, yielding a result of (125/3√2) cm³. Participants emphasize the importance of clear assumptions and calculations to ensure accuracy for exam preparation.
beh4R
Hello .
I am in the end of my exams and i have to do a geometry figure like a pyramid ( view image ) below
Now i should find the Perimeter, Volume and Surface of this figure .
Lengths are all 5 cm, Can somebody find and write the
Permiter,volume and surface for this figure please it's urgent :confused: :confused:
Mathematics news on Phys.org
beh4R said:
Hello .
Good morning,
I've to do a lot of guessing, so if I guessed correctly you can finish the problem, otherwise you have to provide us with additional detailed informations:
1. I assume that the figure shows a sector of a circle. If so the figure is the curved surface of a cone with the slanted line s = 5 cm and the arc a = 5 cm.
2. The area $$A_s$$ of a sector is calculated by: $$A_s = \frac12 \cdot a \cdot s$$
3. The arc of the sector is the circumference of the base circle of the cone. You can determine the radius r of the base circle by: $$a = 2 \pi \cdot r$$
4. The volume of a cone is calculated by: $$V = \frac13 \cdot \pi \cdot r^2 \cdot h$$
where h denotes the height of the cone.
5. Use Pythagorean theorem to derive h from r and s.
I'll leave it to you to calculate the complete surface area of the cone.
... and btw I couldn't imagine what a perimeter of a solid could be? :confused:
Hello, beh4R!
figure like a pyramid. .All lengths are 5 cm.
Find the perimeter, volume, and surface area.
Code:
           * * * 5
        5 *   *   *
       *         * * 5
I assume this is a pyramid with a square base.There are four slanted edges of length 5.
The base is a square with side 5.
The perimeter is: 4\cdot5 + 4\cdot 5 \:=\:40\:cm.
There are four equilateral triangles with side 5.
. . Their area is: 4\cdot\tfrac{\sqrt{3}}{4}(5^2) \,=\,25\sqrt{3}\,cm^2
. . Its area is 5^2\,=\,25\,cm^2
Surface area: .(25\sqrt{3} + 25)\,cm^2
Slice the pyramid through two opposite slanted sides.
Code:
        5 * : * 5
      *  *  *_ *  *
           5√2
We have an isosceles right triangle.
Its height is \tfrac{5}{\sqrt{2}}\,cm.
Volume: .\tfrac{1}{3}(5^2)\left(\tfrac{5}{\sqrt{2}}\right) \:=\:\frac{125}{3\sqrt{2}}\,cm^3
soroban said:
Hello, beh4R!
Code:
        5 * : * 5
      *  *  *_ *  *
           5√2
ok thnaks so much i will write this in my notebook . hope its correct and to not remain in exam :) God bless you (Inlove)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
