Help with Goldstein Classical Mechanics Exercise 1.7
In summary, the problem at hand is to prove the equation $\frac{\partial \dot T}{\partial \dot q} - 2\frac{\partial T}{\partial q} = Q$, which arises in the context of solving the Goldstein classical mechanics exercises 1.7. Using the Lagrange equation, the goal is to show that $\frac{\partial \dot T}{\partial \dot q} = \frac{d}{dt} \frac{\partial T}{\partial \dot q} + \frac{\partial T}{\partial q}$. By expanding the left and right hand sides of the equation, it can be shown that $\frac{\partial T}{\partial \dot q} \frac{\
lriuui0x0
101
25
I'm trying to solve the Goldstein classical mechanics exercises 1.7. The problem is to prove:
$$\frac{\partial \dot T}{\partial \dot q} - 2\frac{\partial T}{\partial q} = Q$$
Below is my progress, and I got stuck at one of the step.
Now since we have langrange equation:
$$\frac{d}{dt} \frac{\partial T}{\partial \dot q} - \frac{\partial T}{\partial q} = Q$$
We only need to prove:
$$\frac{\partial \dot T}{\partial \dot q} = \frac{d}{dt} \frac{\partial T}{\partial \dot q} + \frac{\partial T}{\partial q}$$
Assuming ##T## is a function of ##T(q, \dot q, t)##, expanding LHS:
\begin{aligned}
& \frac{\partial}{\partial \dot q} \dot T \\
=& \frac{\partial}{\partial \dot q} (\frac{\partial T}{\partial t} + \frac{\partial T}{\partial q} \dot q + \frac{\partial T}{\partial \dot q} \ddot q) \\
=& \frac{\partial ^2 T}{\partial \dot q \partial t} + \frac{\partial ^2 T}{\partial \dot q \partial q} \dot q + \frac{\partial T}{\partial q}\frac{\partial \dot q}{\partial \dot q} + \frac{\partial^2 T}{\partial \dot q \partial \dot q} \ddot q + \frac{\partial T}{\partial \dot q}\frac{\partial \ddot q}{\partial \dot q} \\
=& \frac{\partial ^2 T}{\partial \dot q \partial t} + \frac{\partial ^2 T}{\partial \dot q \partial q} \dot q + \frac{\partial T}{\partial q} + \frac{\partial^2 T}{\partial \dot q \partial \dot q} \ddot q + \frac{\partial T}{\partial \dot q}\frac{\partial \ddot q}{\partial \dot q}
\end{aligned}
Expanding RHS:
\begin{aligned}
& \frac{d}{dt}\frac{\partial T}{\partial \dot q} + \frac{\partial T}{\partial q} \\
=& \frac{\partial^2 T}{\partial t \partial \dot q} + \frac{\partial ^2 T}{\partial q \partial \dot q} \dot q + \frac{\partial^2 T}{\partial \dot q \partial \dot q} \ddot q + \frac{\partial T}{\partial q}
\end{aligned}
Since second order partial derivative commutes, cancelling terms we get:
\frac{\partial T}{\partial \dot q} \frac{\partial \ddot q}{\partial \dot q} = 0
However I don't know how to show this equation is true. Is it because ##\frac{\partial \ddot q}{\partial \dot q} = 0##? But can't acceleration be a function of velocity?
Likes Delta2
I think
[tex]\frac{\partial {\ddot{q}}}{\partial{\dot{q}} }=\frac{d}{dt}\frac{\partial{\dot{q}}}{\partial{\dot{q}}}=\frac{d}{dt}1=0[/tex]
  • Wow
Likes Delta2
anuttarasammyak said:
I think
Can you elaborate on why
\frac{\partial \ddot q}{\partial \dot q} = \frac{d}{dt} \frac{\partial \dot q}{\partial \dot q}
A hint would be that ##q^i, \dot{q}^i, \ddot{q}^i## are functions only on time, therefore the partial differentials of (the members of) one set with respect to (members of) another set are zero.
I exchange order of ##\frac{\partial }{\partial \dot{q}}## and ##\frac{d}{dt}## applying on ##\dot{q}## observing that the initial one is ##\frac{\partial }{\partial \dot{q}}\frac{d}{dt}\dot{q}##.
Likes Delta2
I think ##\dot q## and ##\ddot q## are considered to be independent variables, pretty much the same way ##q,\dot q## are considered to be independent.
But this brings up my eternal question regarding the Lagrangian and its partial derivatives: How can ##q(t)## and ##\dot q(t)## can considered to be independent, since we can write ##t=q^{-1}(q(t))## and replace that in ##\dot q(t)## which will be ##\dot q(q^{-1}(q(t))## hence ##\dot q## seems to be some sort of composite function of ##q(t)## therefore not independent.
Likes anuttarasammyak
Delta2 said:
But this brings up my eternal question regarding the Lagrangean and its partial derivatives: How can ##q(t)## and ##\dot q(t)## can considered to be independent, since we can write ##t=q^{-1}(q(t))## and replace that in ##\dot q(t)## which will be ##\dot q(q^{-1}(q(t))## hence ##\dot q## seems to be some sort of composite function of ##q(t)## therefore not independent.
Each ##\delta q(t)## brings corresponding ##\delta \dot{q}(t)## in variation of path in the least action principle. So they are dependent. In mathematics of deriving Lagrange equation from the least action principle, I observe partial derivatives appear "as if" q and ##\dot{q}## are independent.
The independency comes from convention in Lagrangean derivatives mathematics, not from their physical nature. It is my understanding. I appreciate someone correct and teach me for better understanding.
Likes Delta2
I struggled with that too. The point is that at this stage you don't know the relationship between ##q## and ##\dot{q}##. Saying that they are independent is saying that at some time ##t## the particle could be at any position ##q## at any speed ##\dot{q}## so at time ##t+dt## it could also be at any ##q## with any ##\dot{q}## - it's a statement of your total ignorance (no offence meant! 😁). Fortunately Euler and Lagrange have provided us with a means to identify the family of relationships between ##q## and ##\dot{q}## that extremise the action.
Likes ergospherical, Delta2 and dextercioby
To re-state, ##q##, ##\dot q##, etc. are independent variables (constituting the coordinate space), unless they are evaluated on a solution to the equations of motion (in which case ##q = q(t)##, ##\dot q = \dot q(t)##, etc.)
[Edit: just like the coordinates ##x, y## spanning the Cartesian plane are independent variables unless they are evaluated on a specified trajectory e.g. a parabola: ##y = t^2, x = t##]
  • Love
Likes dextercioby, Ibix, Delta2 and 1 other person
I think you gave me the most satisfying answer young man, how can you be so young and so good !?? ( e hehe I know you are eto, dw).
Likes weirdoguy
Is it a general math theorem that total derivative and partial derivative commutes like this? I only know that the second order partial derivative commutes. Can you link some justification?
I was wondering about this a while ago as well, what I ended up with somewhat understanding is this. Take a function ##f(x, y)##, now from the perspective of this function itself surely ##x, y## are independent. This doesn't prevent you to plug in ##y## to be ##g(x)## though. So you can either view ##f## as a function of two variables ##x## and ##y##, or you can view ##f## as a composite function of one variable ##x##. It's up to you if you want to "look inside" and analyse the function as a composite function or not. You can surely choose to analyse the function only in its own form. Treating the function on its own is the more general version of taking special combination of arguments such that they correlate with each other. Therefore the analysis on the function on its own will hold when the arguments are correlating with each other as well.
This link also might be helpful. https://math.stackexchange.com/ques...iables-where-some-are-dependent-on-each-other
Likes Delta2
I had no concern about commutability. I would appreciate it to have some counterexamples.
Velocity is the first derivative of position with respect to time; if the directionality is not complicated (not more than a single vector), then acceleration is simply the second such derivative (the third is jerk, the fourth is jounce -- some like to call 'jounce', 'snap', so that they can jokingly (rice krispies ad joke) call the fifth and sixth 'crackle' and 'pop'.
I think every student of analytical mechanics stumbles over this issue, and it's partially the fault of the physicists "efficient" mathematical notation.
In the context of d'Alembert's principle and the Lagrangian form of the action principle one has to distinguish between partial derivatives noted with the symbol ##\partial## and total time-derivatives.
The partial derivatives apply to functions ##f(q,\dot{q},\ddot{q},\ldots,t)## and in this context the ##q##, ##\dot{q}##, ##\ddot{q}## etc. are to be interpreted as independent variables. The dots just distinguish these different variables. Thus an expression like
$$\frac{\partial f}{\partial \dot{q}}$$
means that you take the derivative wrt. to ##\dot{q}## considering all other variables of the function ##f## as constant, which is the usual definition of a partial derivatives.
When you take the total time derivative of ##f## you consider ##q## a trajectory parametrized with time and you consider ##\dot{q}##, ##\ddot{q}## etc. as the corresponding time derivatives, i.e.,
$$\dot{q}=\frac{\mathrm{d} q}{\mathrm{d} t}, \quad \ddot{q}=\frac{\mathrm{d}^2 q}{\mathrm{d} t^2}, \quad \text{etc.}$$
From this you get, e.g., a new function by taking the total time derivative of ##f##:
$$g(q,\dot{q},\ddot{q},\ldots,t)=\frac{\mathrm{d}}{\mathrm{d} t} f(q,\dot{q},\ddot{q},\ldots,t)=\dot{q} \frac{\partial}{\partial q} f + \ddot{q} \frac{\partial f}{\partial \dot{q}}+\cdots+\frac{\partial f}{\partial t}.$$
Again the ##q##, ##\dot{q}##,... are to be taken as indepenent variables of ##g##.
Now we can address the question in #1. First we note that the kinetic energy is of the form
$$T=\frac{m}{2} g_{jk}(q) \dot{q}_j \dot{q}_k$$
with Einstein's summation convention (summing tacitly over indices that appear in pairs in an equation).
Then the usual form of d'Alembert's equations of motion read
$$\frac{\mathrm{d}}{\mathrm{d} t} \frac{\partial T}{\partial \dot{q}_j}-\frac{\partial T}{\partial q_j}=Q_j.$$
Here the partial derivatives as well as the total time derivative have to be understood as explained above.
So we have (because we can assume ##g_{jk}=g_{kj}##)
$$\frac{\partial T}{\partial \dot{q}_j} = m g_{jk}(q) \dot{q}_k$$
and thus
$$\frac{\mathrm{d}}{\mathrm{d} t}\frac{\partial T}{\partial \dot{q}_j}=m g_{jk}(q) \ddot{q}_k + m \frac{\partial g_{jk}(q)}{\partial q_l} \dot{q}_k \dot{q}_l$$
and
$$\frac{\partial T}{\partial q_j}=\frac{m}{2} \frac{\partial g_{kl}}{\partial q_j} \dot{q}_{k} \dot{q}_l$$
On the other hand we have
$$\dot{T}:=\frac{\mathrm{d} T}{\mathrm{d} t}=m g_{jk}(q) \dot{q}_j \ddot{q}_k + \frac{m}{2} \frac{\partial g_{jk}}{\partial q_l} \dot{q}_j \dot{q}_k \dot{q}_l.$$
From this we get
$$\frac{\partial \dot{T}}{\partial \dot{q}_j}=m g_{jk} \ddot{q}_k+m \frac{\partial g_{jk}}{\partial q_l} \dot{q}_k \dot{q}_l + \frac{m}{2} \frac{\partial g_{kl}}{\partial q_j} \dot{q}_k \dot{q}_l.$$
Then we find
$$Q_j=\frac{\mathrm{d}}{\mathrm{d} t} \frac{\partial T}{\partial \dot{q}_j}-\frac{\partial T}{\partial q_j}=m g_{jk}(q) \ddot{q}_k + m \frac{\partial g_{jk}(q)}{\partial q_l} \dot{q}_k \dot{q}_l-\frac{m}{2} \frac{\partial g_{kl}}{\partial q_j} \dot{q}_{k} \dot{q}_l= \frac{\partial \dot{T}}{\partial \dot{q}_j}-2 \frac{\partial T}{\partial q_j}.$$
Likes sysprog, dextercioby and Delta2
FAQ: Help with Goldstein Classical Mechanics Exercise 1.7
What is the purpose of Exercise 1.7 in Goldstein Classical Mechanics?
The purpose of Exercise 1.7 is to help students understand and apply the concepts of kinematics and dynamics in classical mechanics. It also serves as a way for students to practice problem-solving and critical thinking skills.
What are the main topics covered in Exercise 1.7?
Exercise 1.7 covers topics such as displacement, velocity, acceleration, and the equations of motion in one dimension. It also introduces the concept of free fall and how to calculate the position and velocity of an object in free fall.
What are some common challenges students face when completing Exercise 1.7?
Some common challenges students face when completing Exercise 1.7 include understanding the equations of motion and how to apply them correctly, as well as properly interpreting and solving problems involving free fall.
Are there any helpful resources or tips for completing Exercise 1.7?
Yes, there are several helpful resources and tips for completing Exercise 1.7. These include reviewing the relevant equations and concepts before attempting the exercise, breaking down the problem into smaller, manageable parts, and seeking help from a teacher or tutor if needed.
How does Exercise 1.7 relate to real-world applications?
Exercise 1.7 relates to real-world applications by providing a foundation for understanding the motion of objects in the physical world. The concepts and equations covered in this exercise are used to analyze and predict the motion of objects in various scenarios, such as in sports, engineering, and space exploration.
