Help with Linear Algebra proof
In summary, a linear algebra proof is a mathematical argument that uses logical reasoning to show the truth of a statement or theorem in linear algebra. To determine which properties or theorems to use in a proof, one should first identify the concept being proven and then consider related properties or theorems. Common mistakes to avoid in a linear algebra proof include incorrect algebraic manipulations, assuming false properties, and insufficient explanations. Examples and counterexamples can be useful in a proof to illustrate a concept or disprove a statement. To improve one's proof skills, it is recommended to practice regularly, seek help from a tutor or professor, and study proofs in textbooks or online resources. Breaking down a proof into smaller steps and providing clear explanations can also be
evilpostingmong
339
Suppose S, T [tex]\in[/tex] the set of linear transformations
from V to V. Prove that ST and TS have the same eigenvalues.
T=[tex]\lambda[/tex]I
let v[tex]\in[/tex]V.
For TS
T(Sv)=T(I[tex]\lambda[/tex]v)=[tex]\lambda[/tex]T(Iv)
=[tex]\lambda[/tex]'[tex]\lambda[/tex]Iv.
For ST
S(Tv)=S([tex]\lambda[/tex]'v)=[tex]\lambda[/tex]'S(Iv)=
[tex]\lambda[/tex]'IS(v)=[tex]\lambda[/tex]'I[tex]\lambda[/tex]Iv
Your "relevant equation" T = [itex]\lambda[/itex]I doesn't seem at all relevant, as far as I can see.
If [itex]\lambda[/itex] is an eigenvalue of T, then for some v [itex]\neq[/itex] 0,
Tv = [itex]\lambda[/itex]v.
I would approach this by assuming that [itex]\lambda_1[/itex] and [itex]\lambda_2[/itex] are eigenvalues of ST and TS, then showing that the two eigenvalues are equal.
For ST
Knowing that Tv=[tex]\lambda[/tex]v, STv=S[tex]\lambda[/tex]v
=[tex]\lambda[/tex]Sv=[tex]\lambda[/tex] [tex]\lambda[/tex]'v
[tex]\lambda[/tex] [tex]\lambda[/tex]'=[tex]\lambda[/tex]1
For TS
knowing that Sv=[tex]\lambda[/tex]'v, TSv=T[tex]\lambda[/tex]'v
=[tex]\lambda[/tex]'Tv since we know from ST that Tv=[tex]\lambda[/tex]v
we get [tex]\lambda[/tex]' Tv=[tex]\lambda[/tex]'[tex]\lambda[/tex]v=[tex]\lambda[/tex] [tex]\lambda[/tex]'v
[tex]\lambda[/tex][tex]\lambda[/tex]'=[tex]\lambda[/tex]2
evilpostingmong said:
For ST
For TS
That's really not a very good proof at all. It only works if S and T have the same eigenvectors. The result is true even if they don't. You want to show ST and TS have the same characteristic polynomial. Start with the case where S is invertible. Can you show ST and TS are similar matrices?
STv=[tex]\lambda[/tex]v
TSw=[tex]\lambda[/tex]2w
STv-[tex]\lambda[/tex]v=0
TSw-[tex]\lambda[/tex]2w=0
(ST-[tex]\lambda[/tex])v=0
(TS-[tex]\lambda[/tex]2)w=0
ST-[tex]\lambda[/tex]=0
TS-[tex]\lambda[/tex]2=0
ST=[tex]\lambda[/tex]
TS=[tex]\lambda[/tex]2
T=S^-1[tex]\lambda[/tex]2
plugging in S^-1[tex]\lambda[/tex]2 to ST-[tex]\lambda[/tex]=0 for T
S(S^-1[tex]\lambda[/tex]2)-[tex]\lambda[/tex]=0
I[tex]\lambda[/tex]2-[tex]\lambda[/tex]=0
[tex]\lambda[/tex]2=[tex]\lambda[/tex]
since ST=[tex]\lambda[/tex] and TS=[tex]\lambda[/tex]2
and [tex]\lambda[/tex]=[tex]\lambda[/tex]2
(ST-[itex]\lambda[/itex])v=0
(TS-[itex]\lambda[/itex]2)w=0
do not imply
ST-[itex]\lambda[/itex]=0
TS-[itex]\lambda[/itex]2=0
Dick's suggestion is good, and if you start with a singular matrix S,you can substitute S-[itex]\epsilon[/itex]I instead of S, and let [itex]\epsilon[/itex] tend to 0. It's a standard homotopy trick frequently used in linear algebra
still don't get it
Do you know similar matrices have the same eigenvalues? Can you show if S is nonsingular then ST and TS are similar? Do you know that nonsingular matrices are dense in the space of all matrices? Do you know that the coefficients of the characteristic polynomial are continuous functions of the elements of the matrices? You have to put all of these things together to get it. Big hint: TS=S^(-1)*(ST)*(S).
Oh, my bad, I should've explained that I'm taking this off of Axler's book, which is my text, he says nothing of similar matrices,
so I'm not too familiar with those. Though I see your point in that there
can be an eigenvector (1,0) that undergoes [tex]\lambda[/tex](1,0)= (2*1, 2*0)=(2,0)
and another that undergoes [tex]\lambda[/tex](0, 1)=(2*0, 2*1)=(0,2)
the same transformations.
ST=[tex]\lambda[/tex]1
TS=S^(-1)[tex]\lambda[/tex]1S
TS=[tex]\lambda[/tex]1I
Since [tex]\lambda[/tex]1=TS=[tex]\lambda[/tex]2,
[tex]\lambda[/tex]1=[tex]\lambda[/tex]2
ST=T^(-1)TST
ST=T^(-1)[tex]\lambda[/tex]2T
ST=I[tex]\lambda[/tex]2
I still don't know what I just did. Does the one below work?
If not, then I'll stop trying to prove this in this manner.
w and v are either different or the same, as opposed to just using v.
I'm not trying to be the my proofs better than yours guy,
I just need convincing.
For ST
[tex]\lambda[/tex] [tex]\lambda[/tex]'=[tex]\lambda[/tex]1For TS
knowing that Sv=[tex]\lambda[/tex]'w, TSv=T[tex]\lambda[/tex]'w
=[tex]\lambda[/tex]'Tw since we know from ST that Tv=[tex]\lambda[/tex]v
we get [tex]\lambda[/tex]' Tw=[tex]\lambda[/tex]'[tex]\lambda[/tex]v=[tex]\lambda[/tex] [tex]\lambda[/tex]'w
Check your latex codes,
and I think Dick has given the proof:TS=S^(-1)*(ST)*(S), that's all of it, plus the homotopy trick I mentioned,then the proof will be finished.
ST=T^(-1)TST
For ST
For TS
I really don't think you can prove the general case that way. The eigenvalues and eigenvectors of S and T don't have to be the same as those of ST and TS. Nor is it generally true that the product of the eigenvalues of S and T are the eigenvalues of ST and TS. Try some nontrivial examples. Say S=[[2,1],[1,2]] (eigenvalues 3 and 1) and T=[[1,1],[8,-1]] (eigenvalues -3 and 3). The eigenvalues of ST or TS are (9+/-3*sqrt(21))/2. Now do you believe me?
Oh, ok I see that. Yeah, that's my problem with these proofs,
I tend to neglect some cases. Thanks for your efforts.
Related to Help with Linear Algebra proof
1. What is the definition of a linear algebra proof?
A linear algebra proof is a mathematical argument that uses logical reasoning to show that a statement or theorem in linear algebra is true. It typically involves manipulating equations and using properties of vectors, matrices, and other algebraic objects.
2. How do I know which properties or theorems to use in a linear algebra proof?
In a linear algebra proof, you will often be given specific properties or theorems to use. However, if you need to choose which ones to use, start by looking at the given statement or equation and identifying what is being asked to prove. Then, think about what properties or theorems you know that relate to that concept.
3. What are some common mistakes to avoid in a linear algebra proof?
Some common mistakes in linear algebra proofs include using incorrect algebraic manipulations, assuming properties that are not true, and not showing all of your steps or explanations. It is important to carefully check your work and make sure that each step is justified.
4. Can I use examples or counterexamples in a linear algebra proof?
Yes, using examples or counterexamples can be helpful in a linear algebra proof. They can help illustrate a concept or property, and can also be used to show that a statement is not always true by providing a counterexample.
5. Are there any resources or tips for improving my linear algebra proof skills?
There are many resources available for improving your linear algebra proof skills. Some tips include practicing regularly, seeking help from a tutor or professor, and studying proofs in textbooks or online resources. It can also be helpful to break down a proof into smaller steps and clearly explain each step.
  • Linear and Abstract Algebra
