Help with Logarithms: Find 2^A
  • MHB
  • Thread starter IHateFactorial
  • Tags
    Logarithms
In summary, the problem is finding 2^A, where A is equal to 1/6 of the difference of the third powers of the logarithms of 3, 6, 12, and 24. The logs can be factored to 3 + 2 to some power of n, which leads to a simplified expression for A. However, there may be an error in the calculations and further assistance is needed.
IHateFactorial
So, there's this problem:
\(\displaystyle A = \frac{1}{6}((\log_{2}\left({3})\right)^3 - (\log_{2}\left({6})\right)^3 - (\log_{2}\left({12})\right)^3 - (\log_{2}\left({24})\right)^3)\)
Find \(\displaystyle 2^A\)
What I've figured out is that all the logs factorize to 3 + 2 to some power of n.
\(\displaystyle \log_{2}\left({3}\right)=\log_{2}\left({3\cdot2^0}\right)\)
\(\displaystyle \log_{2}\left({6}\right)=\log_{2}\left({3\cdot2^1}\right)\)
\(\displaystyle \log_{2}\left({12}\right)=\log_{2}\left({3\cdot2^2}\right)\)
\(\displaystyle \log_{2}\left({24}\right)=\log_{2}\left({3\cdot2^3}\right)\)
Solving THAT gives me:
\(\displaystyle A = \frac{1}{6}((\log_{2}\left({3})\right)^3 - (\log_{2}\left({3})+1\right)^3 - (\log_{2}\left({3})+2\right)^3 - (\log_{2}\left({3})+3\right)^3)\)
\(\displaystyle A = \frac{1}{6}(-2(\log_{2}\left({3})\right)^3 - 6(\log_{2}\left({3})\right)^2 - 14(\log_{2}\left({3})\right)-36\)
\(\displaystyle A = \frac{-1}{3}(\log_{2}\left({3})\right)^3 - (\log_{2}\left({3})\right)^2 - \frac{7}{3}(\log_{2}\left({3})\right)-6\)
And... Now? I believe I screwed up SOMEWHERE aloing that line... And I'm completely stuck as to how to go on, any ideas?
Mathematics news on Phys.org
I am very curious and wanted to ask if you're certain that you've typed everything correctly for the expression for $A$?
FAQ: Help with Logarithms: Find 2^A
1. What is a logarithm?
A logarithm is the inverse operation of exponentiation. It is a mathematical function that helps us solve equations with exponential terms.
2. What is the base of a logarithm?
The base of a logarithm is the number that is raised to a certain power to produce a given value. For example, in the logarithm 2^3 = 8, 2 is the base.
3. How do I solve for A in the equation 2^A = 16?
To solve for A, we can rewrite the equation using logarithms. The base of the logarithm should match the base of the exponential term. So, in this case, we can rewrite 2^A = 16 as log2(16) = A. Using a calculator, we can find that log2(16) = 4, so A = 4.
4. Can I use any base for logarithms?
Yes, you can use any positive number as the base for logarithms. However, the most commonly used bases are 10 and e (approximately 2.71828).
5. How can I use logarithms to solve real-world problems?
Logarithms are used in a variety of fields such as science, finance, and engineering. They can help us solve problems involving exponential growth and decay, measure the intensity of earthquakes, and calculate the pH of a solution. In general, logarithms are useful for simplifying complex equations involving exponential terms.
