Help with mechanics problem-With my math in particular
  • Thread starter JDStupi
  • Tags
    Mechanics
In summary, the conversation is about a person seeking help with a mechanics problem involving integrals and finding the velocity of a mass in a medium with drag force. The person shares their attempt at solving the problem and asks for feedback and advice.
JDStupi
117
Help with mechanics problem--With my math in particular
Hello all, I would just like to let you know that this is a fairly simple problem that is giving me trouble because of my sub par knowledge of integrals and I appreciate the help.
1.
A mass m has velocity v=v[itex]_{0}[/itex] at time t=0 and coasts along the x-axis in a medium where the drag force is F(v)=-cv[itex]^{}3/2[/itex]. Use the method of Problem 2.7 [seperation of variables] to find v in terms of the time t and the other given parameters. At what time (if any) will it come to rest?
2.t=m[itex]\int[/itex][itex]dv\frac{dv}{f(v)}[/itex] (and that integral is a definite integral from v to v[itex]_{0}[/itex] I just didn't want to mess up the rest.)
Ok so the previous problem was simple enough (that was the problem this one was referring to) It was to simply use the separation of variables method to solve the special case that F(v)=F[itex]_{0}[/itex] a constant.
I went through the normal steps:
m[itex]\frac{dv}{dt}[/itex]=F
dv=[itex]\frac{F}{m}[/itex]dt
[itex]\int[/itex]dv=[itex]\int\frac{F}{m}[/itex]dt
v=[itex]\frac{Ft}{m}[/itex]+v[itex]_{0}[/itex]
and
x=[itex]\frac{Ft{2}}{m}[/itex]+v[itex]_{0}[/itex]t+x[itex]_{0}[/itex].
Now, here is the thing, because of my general lack of confidence in my mathematical abilities I am simply posting here so that you guys can review what I have done, point out the flaws in it and perhaps give me hints and/or other forms of help if you see something that I did wrong, or even if it could've been done better or what have you. I feel as though my answer is wrong though, because of its complexity.
m[itex]\frac{dv}{dt}[/itex]=-cv[itex]^{3/2}[/itex]
= m[itex]\frac{dv}{v^{3/2}}[/itex]=-cdt
= m[itex]\int[/itex][itex]^{v}_{vo}[/itex]=[itex]\int[/itex]-cdt
= 2m(([itex]\frac{1}{\sqrt{v_{o}}}[/itex])-([itex]\frac{1}{\sqrt{v}}[/itex]))=-ct
= (([itex]\frac{1}{\sqrt{v_{o}}}[/itex]))-(([itex]\frac{1}{\sqrt{v}}[/itex]))=[itex]\frac{-ct}{2m}[/itex]
[itex]\sqrt{v}[/itex]=[itex]\frac{\sqrt{v_{o}}2m}{((2m)+(\sqrt{v_{o}}ct))}[/itex]
v=[itex]\frac{4m^{2}v_{o}}{4m^{2}+4m\sqrt{v_{0}}ct+v_{o}c^{2}t^{2}}[/itex]
And so by the time I get to that point, I don't see any simplification that would make that look any nicer and am lead to believe that I did it wrong because of that messy answer, and so I turn to you guys for advice. Thank you very much to all who help.
I got the same thing without looking at your calc.
Looks like there is no t that makes v=0 other than infinity.
FAQ: Help with mechanics problem-With my math in particular
What is the best approach to solving a mechanics problem with math?
The best approach to solving a mechanics problem with math is to first identify the key concepts and equations involved. Then, carefully read and understand the problem, paying attention to any given values or known information. Next, draw a diagram to visualize the problem and label any known and unknown variables. Finally, use the appropriate equations and algebraic manipulations to solve for the unknown variable.
Can you provide some tips for solving mechanics problems with math?
Some tips for solving mechanics problems with math include: always double check your units and conversions, use the correct formula for the given problem, break down complex problems into smaller, simpler parts, and use diagrams and visualizations to better understand the problem.
How can I improve my understanding of mechanics and math?
To improve your understanding of mechanics and math, practice solving various types of problems and equations. Additionally, try to understand the underlying concepts and principles instead of just memorizing formulas. Seek help from teachers, tutors, or online resources if you are struggling with a specific concept or problem.
What are some common mistakes to avoid when solving mechanics problems with math?
Common mistakes to avoid when solving mechanics problems with math include: incorrect conversions or units, using the wrong formula, not paying attention to significant figures, and making careless errors in calculations. It is important to double check your work and make sure your answer makes sense in the context of the problem.
How can I apply my knowledge of mechanics and math in real-life situations?
Mechanics and math are used in various real-life situations, such as designing structures, analyzing and predicting motion, and understanding the behavior of fluids and gases. By practicing and applying your knowledge of these subjects, you can develop problem-solving skills that can be applied in many different fields and industries.
