Help with Monotonic Sequence Convergence
In summary, the conversation discussed the monoticity of a sequence and the investigation of its convergence using the Leibniz test. The sequence in question is \frac{2\ln(n)}{\sqrt{n+1}}, and it was shown that it decreases from n=9 onwards. However, when investigating convergence, the first few terms can be ignored. The conversation also touched on finding a value for x that satisfies a certain inequality and using this to prove the divergence of a series. The use of Wolfram Alpha in solving the problem was also mentioned, with the conclusion that it is not always accurate.
Lisa91
29
Could anyone help me out with the monoticity of this sequence please?
[tex] \frac{2\ln(n)}{\sqrt{n+1}} [/tex]. It should decline. I am investigating the convergence of one series and I need it to do the Leibniz test.
Let $f(x) = \frac{2\ln x}{\sqrt{x+1}}$. Differentiate it, and show that $f'(x)<0$ whenever $x>9$. This will show that the sequence $\frac{2\ln(n)}{\sqrt{n+1}}$ decreases from $n=9$ onwards. Notice that this sequence does not decrease to start with, in fact it increases from $n=1$ up to $n=8$. But that does not matter when investigating convergence, because convergence is unaffected by ignoring the first few terms.
I end up with [tex] e^{2x} \cdot e^{2} > x^{x} [/tex]. Is it ok? What shall I do with it?
Does the limit of this guy equal zero?
what you are looking for is $x$ such that:
$2x + 2 < x\log(x)$ (you want $f$ to be DECREASING).
note that if $x>e$ the RHS is increasing faster than the LHS, so if we find some $x>e$ with the above inequality true, the LHS will never "catch up" for larger $x$.
one $x$ we might try is:
$x = e^2$, unfortunately:
$2e^2 + 2 > 2e^2$.
how about $x = e^2 + 2$?
When [tex] x = e^{2} +2 [/tex] we get [tex] 2x+2< x \ln(x) [/tex]. So, this is not what I want.
Ok, I thought I could solve it on my own but it seems to be much more complicated. I have a series [tex] \sum (-1)^n \frac{2\ln(n)}{\sqrt{n+1}} [/tex]. I thought I could use the Leibniz test but even wolfram alpha shows that the series doesn't converge. Could you give any hints how to prove the divergence of this series?
Hi Lisa91, :)
Refer Opalg's post #2 and you can show that \(\frac{\ln(n)}{\sqrt{n+1}}\) is a decreasing sequence of positive numbers. Then by the Leibniz test the series \(\sum (-1)^n \frac{\ln(n)}{\sqrt{n+1}}\) converges.
Kind Regards,
Sudharaka.
Do think wolfram alpha is wrong in this case?
Yes, wolfram is not always correct. :) Can you link me to the answer that wolfram gave? >>Here<< is what I got using wolfram. Note that it doesn't say anything about convergence/divergence.
how so? you want $2x+2$ to be dominated by $x\log(x)$, for this means that:
$\displaystyle f'(x) = \frac{2x+2 - x\log(x)}{(2x)(x+1)(\sqrt{x+1})} < 0$
that is, f is decreasing.
in fact: $e^2 + 2 \sim 9.389$ so the sequence:
$\displaystyle \frac{2\log(n)}{\sqrt{n+1}}$
is definitely decreasing for $n \geq 10$
my input for the series you seem to actually want on wolframalpha is here:
sum from n=1 to infinity (-1)^n(2log(n))/((n+1)^(1/2)) - Wolfram|Alpha
it merely says the results are inconclusive, but if you look at the partial sums for 600 terms, you can see it's very SLOWLY starting to converge.
by the way the function:
$\displaystyle f(x) = \frac{2\log(x)}{\sqrt{x+1}}$
is quite "flat", so the convergence of your original sequence (and it does converge, to 0, in fact) is very slow.
my guess is that it (the alternating series) converges to around 0.127 or so...
FAQ: Help with Monotonic Sequence Convergence
What is a monotonic sequence?
A monotonic sequence is a sequence of numbers that either consistently increases or decreases. This means that each term in the sequence is either larger or smaller than the previous term.
What is the difference between a monotonic sequence and a convergent sequence?
A monotonic sequence is a type of sequence that either increases or decreases, while a convergent sequence is a type of sequence that approaches a specific value as the sequence continues. A monotonic sequence can be either convergent or divergent.
How can I tell if a monotonic sequence is convergent or divergent?
If a monotonic sequence is increasing and bounded above, it is convergent. If it is decreasing and bounded below, it is also convergent. On the other hand, if a monotonic sequence is unbounded, it is divergent.
What is the importance of monotonic sequence convergence in mathematics?
Monotonic sequence convergence is important in mathematics because it helps us determine the behavior of a sequence as it approaches infinity. It also allows us to prove the convergence or divergence of a sequence, which has many applications in calculus and other areas of mathematics.
Can a monotonic sequence be both convergent and divergent?
No, a monotonic sequence can only be either convergent or divergent. If it is both increasing and decreasing at different points in the sequence, it is considered oscillating and is neither convergent nor divergent.
