Help with motocycle lighting project
In summary, Rick suggests using a small car battery to power the bike's lights rather than using the 200W coil rectifier and regulator. He also warns that running the lights from multiple RC type batteries could damage them.
agent141
I am in the middle of a project, building an on road bike from an off road model and I am to the electrical system the coil I am getting is 200w I will be running probably 80w of lights and some led signals maybe 160w of lights if I feel the need to double the headlights , anyway my Question: with the 200w coil rectifier and regulator I would like to keep the battery VERY small I thought of using the RC type batteries in a pack to 12v are these or is this small battery pack going to have enough capacity / will it handle the 200w coil , maybe I could run 2 packs in parallel . P.S. I only need power when the bike is running , it's kick started and what’s listed above is all the draw.
Comments better ideas?
Rick
200W is a lot of drag for you to push! So yeah, having the battery do the work makes more sense. The battery is rated in Amp hours -- that is, the energy stored is listed as current multiplied by time. So a 1Ahr battery can put out 1 Amp for 1 hour, or 1/2 Amp for 2 hours, and so on. Figure out how much current will be drawn by your load, and use that number to see how big of a battery you need.
EDIT -- I just noticed that the title of the thread is "motorcycle". Duh. When I read your comment about a road bike, I thought you meant bicycle, so that's what lead to my comment about "pushing" the 200W (which is a lot for a bicycle!). Sorry for the confusing comment.
Ok , sorry but I understood about half of your reply, how do I figure the current draw? I will be running 4 20 watt lights (80w) and some led's (not much draw).
rick
Power is volts * amps so the current draw is just the total watts / 12V
Note that a typical car battery is designed for high current not deep discharge - you will typically only be able to use half the amp-hours of a car battery without damaging it.
NiMH or lithium ion wil give you morecapcity for less weight/size but are expensive.
Ok then I guess I have a 2 part question are the RC type batteries stacked up to 12v going to have a problem with the 200w input from the coil thru the rectifier? and am I going to have problems drawing that amount from those batteries?
Rick
Would a capacitor be a better idea?
Rick
200W at 12V is 16A, no problem for a lead acid car battery and your engine should be able to handle recharging (200 is around 1/4hp). If you need the lights when the engine isn't running a small car battery 80Ah would be abdle to run them for 2-3hours.
You would typically only want to pull about 4-5A from a small NiMH/LiIon battery so you would need a few of them (one per lamp).
Hi agent141,
This page may help,
http://nordicgroup.us/s78/
I used it as a guide to build a very bright bike light set for little money.
Ok , thanks for the replies BUT I guess I am not asking the question correctly. I will try again. I have an off road bike, I have an aftermarket upgraded coil 200W, I will be adding 80w of lights and some led signals maybe 160w of lights if I feel the need to double the headlights, I have NO room for a lead acid battery, I need to use a very small battery / batteries, the system only needs to power the lights NO starter ect. My question is will the 200w coil, rectifier and regulator fry the RC type batteries (4500 mAh 35A Rate NiMH),(3300 mAh NiMH) bundled together to 12v, or NiMH Battery Pack: 3700 mAh, 12V if it's to much for one pack could I reduce the draw by running 2 packs in parallel. Or is there a better option.
Thanks
Rick
If it says it can take 35Amps then yes, although a 4500mAh @12V would only run a 200W light for 10-15mins
Check that the 35A figure is continuous not just for a fraction of a second at startup and consider where you are mounting them so they can be cooled. Don't bolt them under the fuel tank on top of the engine!
mgb thanks for the quick reply, I do not need any storage , just running the lights when the motor in running, and am I correct in saying that if I run 2 battery packs in parallel it will cut the draw for the individual pack in half?
Rick
If you only need them to run when the motor is runnign - why not just use the bike's battery.
If the bike electrics are 6v and the lights are 12v you will need a dc-dc converter, but you would need that to charge the 12v battery packs anyway.
The bike does NOT have a battery... I am adding that system to it.
rick
Ok, I used to have an old British 2stroke like that, kick start and then everything ran from the alternator - the ligths dimmed when you stopped unless you revved the engine!
The alternator is probably 6v so you would need to boost it to 12V to run the lights or charge the NiMH battery. I don't know if it would put out 200W, I imagine weight is the main concern in an off-road so it is going to be as small as possible.
If the alternator doesn't have enough power to charge the lights then you need either a big battery or more efficent lights.
I guess what I really want to get across is I know what I want to do I just don't know or understand the formulas/ numbers , I have 200w ac from the coil going to a rectifier then regulator to the battery pack / s to a switch to the lights max 170w, my question is will one of these http://www.trailtech.net/040-BATT3.7.html (NiMH Battery Pack: 3700 mAh, 12V) going to work or will I overload it if so can I run 2 in parallel to cut down on the draw. Sorry if I am just not getting it.
Rick
FAQ: Help with motocycle lighting project
1. What is the purpose of the motorcycle lighting project?
The purpose of the motorcycle lighting project is to improve the visibility and safety of the motorcycle while riding in low light or dark conditions. This can include adding additional lights, upgrading existing lights, or installing new lighting features.
2. What are the key components needed for a motorcycle lighting project?
The key components for a motorcycle lighting project may include LED lights, wiring harness, switches, and mounting hardware. It is important to ensure that all components are compatible with your motorcycle's make and model to avoid any installation issues.
3. Can I install the lights myself or do I need professional help?
This depends on your level of expertise and knowledge in motorcycle mechanics and wiring. If you are not confident in your abilities, it is recommended to seek professional help to ensure the lights are installed correctly and safely.
4. What are the different types of lights that can be used for a motorcycle lighting project?
There are various types of lights that can be used for a motorcycle lighting project, including LED lights, halogen lights, and HID lights. Each type has its own advantages and disadvantages, so it is important to research and choose the best option for your specific needs.
5. Are there any regulations or laws I should be aware of when installing additional lights on my motorcycle?
Yes, it is important to research and follow any local laws or regulations regarding motorcycle lighting. Some states have restrictions on the color and placement of lights, so it is important to ensure compliance to avoid any legal issues.
