Dolph1983
- 6
Help with Organic Rankine Cycle Project please!
Moderator's note: this thread is from May 2011
Hi there everyone, I'm posting here in the hope that someone will be willing to help an engineering layman do some calculations, I'm a plumber not an engineer. Thanks to anyone who decides to help me out.
The project:
build an electric generation device using organic rankine cycle and scroll expander as turbine. Fueled by biomass/waste products.
So far i have built a boiler which will raise 80 degrees C in my heat transfer fluid (water) and a pump to deliver the fluid to my heat exchangers.
Rankine circuit will use Butane as working fluid.
Turbine will require a flow of 6 CFM butane vapour at 6bar. This has been tested using an air compressor to simulate butane flow.
Questions:
How do i work out the correct size for my evaporator plate heat exchangers? and my condenser plate heat exchangers?.
Many thanks,
Dolph
The project:
Questions:
Many thanks,
Dolph
