MHB Help with Pre-Exam Test: Algebra Equations & More
  • Thread starter Thread starter Jinxxerz
    Test
The discussion centers on a user seeking help with algebra equations in preparation for an upcoming exam. They express difficulty with various problems, including rationalizing denominators, solving square roots, finding the least common multiple (LCM), and simplifying expressions. Respondents emphasize the importance of demonstrating effort and understanding the order of operations in algebraic expressions. They suggest consulting textbooks for clearer explanations and encourage the user to rewrite problems more clearly for better assistance. Overall, the conversation highlights the need for clarity in mathematical communication and the value of foundational resources.
Jinxxerz
Hello, I'm in need of major help on some equations.. I have an exam coming up for finals and I'm horrid at algebra in general. I'm in intermediate algebra for the second time. Soo.. yeah, help would be greatly appreciated. Thank you! (Please explain step by step.)
1. Rationalize the denominator, assume all variables represent positive numbers:
√81/5 and ^3√5/9x^2
2. Solve: √4q+5=5 and √3x+1=3+√x-4
3. Find the LCM: 35x, 5x^2, 7x^3 ( I tried this over and over and could not figure it out. There are answers given to chose from. None of the answers matched. )
4. Perform the indicated operation: 3x/10x - 9/14x^2
5. Simplify: 12m^2p^2/4m^10p
6: Divide (and simplify): 3x^2/5 / x^3/30
7. Find the domain of f: f(x)= x/4x+3
Thank you for your help! I really appreciate it!
Mathematics news on Phys.org
Hi, and welcome to the forum!
Please familiarize yourself with the http://mathhelpboards.com/rules/, especially rules #8 and 11. As you see, there is some conflict between the requirement that you show some effort and your shortage of time before the test. This may not be the perfect resource for the last-minute help, but let us try to find a middle ground.
I am sure you have a textbook that describes how to solve these types of problems, and you have been presented with example solutions. I think the best you can do is to go back and read that material. Why do you think that what someone writes here would be better than explanations in your textbook? Now, if those explanations are unclear, then please describe your difficulty and we would be happy to help. Describing your problem and showing what you do and don't understand definitely counts as an effort.
I believe many formulas you wrote are not what you in fact intended because of the order of operations. For example, in problem 7 you must mean f$(x)= x/(4x+3)$, that is, $f(x)=\dfrac{x}{4x+3}$. As it is written, $f(x)= x/4x+3$ means $f(x)=\dfrac{x}{4}x+3$. Similarly, $3x/10x$ in problem 4 strictly speaking means $\dfrac{3x}{10}x=\dfrac{3x^2}{10}$ because multiplication and division are done left to right. You don't need to know how to write fractions vertically because all formulas can be written correctly as plain text using parentheses. For example, in problem 2 you probably mean √(3x+1) and not (√3)x+1. Please rewrite your problems putting no more than two in one thread.
One solution.
First, recall how to divide two monomials. If $a,b$ are real numbers and $m,n$ are integers, then
\frac{ax^m}{bx^n}=\frac{a}{b}\cdot\frac{x^m}{x^n}=\frac{a}{b}x^{m-n}\qquad(*)
If $m\ge n$, then the resulting expression is a monomial, but when $m<n$, we say that $bx^n$ does not divide $ax^m$. For example, $3x^2$ divides $6x^3$ and $(6x^3)/(3x^2)=2x$, but $3x^4$ does not divides $6x^3$. If $a$ and $b$ in (*) are integers and $b$ does not divide $a$ but $m\ge n$, then we can still divide the monomials, but the coefficient would be a fraction: e.g., $(6x^3)/(4x^2)=(3/2)x$.
Thus, to find the least common multiple of several monomials, we need to find the maximum degree of $x$ among those monomials. With respect to the coefficient, it is a bit tricky because I don't know the exact definition you were given. The LCM is divisible by every monomial. But in considering (*) above, do we require that $b$ divides $a$ or not? E.g., do we say that the LCM of $6x^3$ and $4x^2$ is $6x^3$ because it is divisible by $4x^2$, even though the resulting coefficient is $6/4=3/2$? Or do we say that the LCM of $6x^3$ and $4x^2$ is $12x^3$ because $(12x^3)/(6x^3)=2$ and $(12x^3)/(4x^2)=3x$, and in both cases the coefficients are integers?
If we require that coefficients are divided evenly (which is more likely), then the LCM of $35x$, $5x^2$ and $7x^3$ is $35x^3$. Indeed, $(35x^3)/(35x)=x^2$, $(35x^3)/(5x^2)=7x$ and $(35x^3)/(7x^3)=5$. The power of $x$ cannot be less than 3 because the LCM must be divisible by $7x^3$. If we don't require that the coefficients divide evenly, then the LCM is $x^3$ or $cx^3$ for any non-zero real number $c$ because $x^3/(35x)=(1/35)x^2$, $x^3/(5x^2)=(1/5)x$ and $x^3/(7x^3)=1/7$. These are still monomials, though with rational, instead of integer, coefficients.
You see that it would be more efficient to consult a textbook. (Smile)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
