MHB Help with Quadratic Equations by completing the square
To solve quadratic equations when the square is on the right side, first rearrange the equation by moving all terms to the left side, changing their signs. For example, from x² = 14x - 33, it becomes x² - 14x + 33 = 0. Then, complete the square by taking half of the linear coefficient (-14), squaring it to get 49, and adding it to both sides. This results in x² - 14x + 49 = 16, allowing for further simplification and solution. Understanding this process clarifies how to handle quadratic equations regardless of the initial position of the square.
Maddsnicole
I understand how to solve these equations when the square is on this side of the equal sign: x2 + 8x + 7 = 27
But when the square is on the other side, I am thrown. Like this one...
x2 = 14x - 33
The solutions manual shows the next step as the following, but what do you do to get to this point?
x2 - 14x + 49 = -33 + 49
Mathematics news on Phys.org
We are given:
$$x^2=14x-33$$
Subtract through by $14x$:
$$x^2-14x=-33$$
Take the coefficient of the linear term which is -14, divide by 2 to get -7, then square to get 49, and so add 49 to both sides:
$$x^2-14x+49=-33+49$$
Does this make sense?
x2 = 14x - 33
I would not have followed the solution manuals next step. From the question
x2 = 14x - 33
I would first move everything over to the left hand side (because this is where the x2 is).
When you do this the terms you move from one side to the other need to change signs (positive becomes negative, negative becomes positive) so you should get this:
x2 - 14x + 33 = 0
From here I would complete the square as normal.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
