Help with quick integration problem
  • Thread starter Pepsi24chevy
  • Tags
    Integration
In summary, the velocity graph provided is a straight line from (0,50) to (10,-50). To solve for x(t), v(t), and a(t), the following equations can be used: v(t) = -10t + 50, a(t) = -10, and x(t) = -5t^2 + 50t. These equations can be derived using calculus or by finding the area under the velocity graph. The correct slope of the graph is -5, not -10 as previously stated.
Pepsi24chevy
65
Say I got this velocity graph. Assuming X=0, at T=0, write correct algebraic expressions for x(t), v(t), and a(t) with appropriate numerical values inserted for all constants.
Graph: (connect lines(-) to make straight line going from 0,50 to 10, -50
Vx (m/s)
50
!-_
! - _
!_______________
! -_ 10
! -_
-50
How would i go about solving this problem?
Well graph wont' show up right, but it starts at (0,50), and it a straight line down to (10,-50)
This is unclear to me.
Can u understand it now?
The velocity graph is a straight line from (0,50) to (10,-50) so it should be easy to calculate that the slope is (-50-50)/(10-0)= -10.
The equation of the velocity is v= -10t+ 50.
Of course, the acceleration is just the slope of that line: -10.
I don't know what math you have to find the position function. If you have taken calculus, the position is an anti-derivative (integral) of the velocity function: the anti-derivative of v=-10t+50 is -5t2+ 50t+ C where C is some constant. Since we are told that x= 0 when t=0, x(0)= -5(0)+ 50(0)+ C= 0 so C= 0. The position function is x(t)= -5t2+ 50t.
If you can't use calculus, in this simple situation (acceleration is constant) you can argue that the change in position is the area under the graph. For fixed T>0, The area under the graph is a trapezoid with one base 50 (at t=0), the other base 50-10T (at t=T) and height t. The area of that trapezoid is (1/2)h(b1+b2)= (1/2)T(50+50-10T)=(1/2)(100T- 10T2)= 50T- 5T2. Since the initial x value was 0, the position is just that change in position:x(t)= 50t- 5t2 just as before.
Yet another way is to argue that, with constant acceleration, we can treat this a a constant velocity problem by averaging the first and last velocities: the first velocity is 50 and the last velocity (at t= T) is 50- 10T so the average is (50+ (50- 10T))/2 = 50- 5T. Moving for time T at constant velocity 50- 5T, the object will move distance T(50- 5T)= 50T- 5T2 just as before.
If I understand this question, you are given a graph with velocity on the y-axis and time on the x-axis.
You then have a straight line from (0,50) to (10,-50), right?
If so, then that line represents the velocity of an object at any given time. From this graph you can imagine a car that is initially traveling at 50mph at time=0, then slows down to zero mph at t=5, and begins to reverse direction to 50mph backwards.
Knowing the following relationships:
x(t) is position of the car at a any given time.
v(t) is velocity at any given time = x'(t)
a(t) is acceleration at any given time = x"(t) or v'(t).
From your graph, you can determine the slope of the velocity. Write this in the form of v(t)=mx+b.
To find the position, x(t), you integrate the expression you wrote for v(t).
To find the acceleration, a(t), you take the derivative of the v(t) expression you wrote.
I hope I understood the question, and let us know if this helps you.
Post your answer here and I will see if it agress with what I have, I hope so!
Halls of Ivy-
I agree with the method of your response, however I think you made an error on the slope. It should be -5. The start point of the graph is (50,0).
Recheck that and let me know what you think.
FAQ: Help with quick integration problem
What is the definition of integration?
Integration is a mathematical process of finding the area under a curve in a given interval. It involves summing up an infinite number of infinitely small rectangles under the curve to find the total area.
What is the purpose of integration?
The main purpose of integration is to find the area under a curve, which has various applications in physics, engineering, and economics. It is also used to calculate displacement, velocity, and acceleration from given data.
What are the different types of integration?
The two main types of integration are definite and indefinite integrals. In definite integration, the limits of integration are specified, and the result is a single numerical value. In indefinite integration, the limits are not specified, and the result is a function.
What are some common techniques for solving integration problems?
Some common techniques for solving integration problems include substitution, integration by parts, partial fractions, and trigonometric substitution. It is important to understand the properties and rules of integrals to effectively solve integration problems.
How can I check if my integration answer is correct?
You can check your integration answer by differentiating it. If the derivative of your answer is the original function, then your integration is correct. You can also use online integration calculators or check your answer using the fundamental theorem of calculus.
