driesel
- 4
Hi,
I have a college project running for which I have to design an automatic car refuelling cell. This includes automatic robot positioning, automatic payment, assisted car alignment et cetera.
I like to stress that neither I nor my fellow students are mechanical or electrical engineers. We are system designers: we look at what technology is out their and we choose and combine what we think fits the design goal.
Anyway... I started this topic to find a solution for a problem I am having concerning the robotic arm that I would like to use to position the fuelling nozzle. Since the position of fuel openings on cars is quite random (atleast in Europe it is 50/50 left/right and then some variation in orientation) I want to have one flexible robotic arm that can serve the majority of cars.
That is why I would prefer a ceiling mounted arm that is mounted on xy linear axes to go from one side to another.
I came across one type of robotic arm from Fanuc which has excellent specs with regard to my needs, namely the M-710iC/20L (http://www.fanucrobotics.be/products/robots/detail.asp?id=310). This robot is very well suited since it has an action radius of +3100 mm.
I have a couple of concerns/questions about this type of robot:
I also thought about mounting a smaller robotic arm on a vertically oriented axis, on which the arm can move up or down, but I cannot decide of this would be a better option or not.
http://img48.imageshack.us/img48/4234/34427566vo2.th.jpg http://g.imageshack.us/thpix.php
Any suggestions are welcome!
P.S. I have put this topic here, since I thought it was a too practical problem to put in the Education section.
greetings,
driesel
- Can I just mount this type of robot to a ceiling without compromising performance?
- This robot weighs 540 kg, which is quite heavy for mounting on xy linear axes. If cost is not important would I be able to reduce mechanical weight by using f.i. Ti-alloys or Carbon fiber composites?
- My application would only require a 5 kg work load (dry-break valve) and 5 kg load on the arms (fuel hoses) while the Fanuc can bear a 20 kg work load. What effect would half that work load have on mechanical weight and motor torque?
- To summarize the above: How low can mechanical weight get if cost is not of importance and taking into account aspects like 5 kg work load, 3 m long action radius ...
greetings,
driesel
