Help with simple electric cirquits
  • Thread starter theneedtoknow
  • Tags
    Electric
In summary, the conversation discusses two different circuit configurations and their effects on the brightness of bulbs in the circuit. In the first configuration, adding more branches will result in all bulbs becoming equally bright, while in the second configuration, the bulbs will not necessarily glow with the same brightness. The conversation also suggests learning Ohm's law and creating graphs to better understand the relationship between voltage, current, and resistance in a circuit.
theneedtoknow
176
I have never studied circuits before and in a couple of weeks I'm going to get into the lab to try some things and get an undersanding ofhow they work. I came across two configurations that I'm going to be trying and I need some help in predicting what will happen.
the first is as seen in this picture (2 separate figures)
http://img443.imageshack.us/img443/3995/circuit1xk2.th.jpg
the round things are bulbs that all have the same resistance
So in the first case with 2 branches:
What will happen to the brightness of Bulb A if i disconnect the wire leading to bulb B?
(I would say..since the 2 branches are parallel, the total resistance of the circuit will go up, so the current will go down and bulb A would be less bright ? )
What will happen to the brightness of Bulb A if the wire is reconnected to bulb B, and you short circuit lamp B?
(My guess is the same...the total resistance of the circuit will go down but by less than in the 1st part, and bulbs B and A will glow brighter than before (and equally bright).
Now adding another parallel branch like in the 2nd figure, what will happen to the brightness of A, B, and C.
(my prediction is that they will become brighter because the total resistance of the circuit descreases)
In general, when I add more branches like this...all bulbs on each branch should glow equaly bright, and all bulbs on the previous brances should get brighter with each new branch I add, correct?
The second setup is as seen in this other horrible picture I drew.
http://img177.imageshack.us/img177/5402/circuit2ks2.th.jpg
This time it uses a constant current instead of a constant voltage supply.
Would the bulbs all glow with the samebrightess? Hmmm I'm not too sure about this one..help?
what will happen to bulbs a and C if you disconnect bulb b?
Well...the total resistance of the circuit should go up and bulbs a and C will glow equally bright I think... If we consider bulbs b and c to form a parallel circuit, removing one will increase te resistance of that part of the circuit and since a and c are now in series, the total resistance would be 2r instead of R + R/2 = 3R/2 so that's why.
What will happen if you short circuit bulb B?
(exactly same thing...resistance goes fom 3r/2 to 2r and bulbs a and c get dimmer)
What will happen when another set of3 bulbs is added as shown in the second part of the picture?
The brightness of all the previous bulbs should go down, since we're adding moreresistors in series...
Can someone tell me if I'm forgetting something, and help me fill in theblanks?
The first thing you should do is learn Ohm's law which is E = I*R. I mean really learn it. For instance you might make three graphs.
Graph 1: Hold voltage constant and graph current versus resistance.
Graph 2: Hold current constant and graph resistance versus voltage.
Graph 3: Hold resistance constant and graph current versus voltage.
With Excel this won't be too difficult.
Once you get a feel for what happens as one of the variables changes, finding the answer will be much easier.
I am happy to see that you are taking an active interest in learning about electric circuits. It is a fascinating subject, and I am sure you will enjoy your time in the lab.
In response to your first question about disconnecting the wire leading to bulb B in the first circuit, your prediction is correct. As you stated, the total resistance of the circuit will increase, causing the current to decrease and resulting in a dimmer bulb A.
When the wire is reconnected to bulb B and you short circuit it, the total resistance of the circuit will decrease even more than in the first scenario. This will cause bulbs A and B to glow brighter, but not equally bright. Since bulb B is short circuited, it will have a lower resistance and will draw more current, resulting in a brighter glow compared to bulb A.
In the second circuit, with the addition of another parallel branch, your prediction is also correct. The total resistance of the circuit will decrease, causing all bulbs to glow brighter.
In regards to the second setup with a constant current source, your prediction is also correct. All bulbs will glow with the same brightness, as the current is constant throughout the circuit.
When disconnecting bulb B, the resistance of the circuit will increase, causing bulbs A and C to glow equally bright. And when short circuiting bulb B, the resistance will decrease, resulting in a dimmer glow for bulbs A and C.
Adding another set of three bulbs in the second part of the picture will indeed decrease the brightness of all the previous bulbs, as the total resistance of the circuit increases.
Overall, your understanding of electric circuits is very good. Keep up the good work and continue to ask questions and make predictions in the lab. That is the best way to learn and gain a deeper understanding of how circuits work. Good luck!
Related to Help with simple electric cirquits
1. What is a simple electric circuit?
A simple electric circuit is a closed loop of conductive material that allows electric current to flow through it. It consists of a power source, such as a battery or outlet, wires to carry the current, and a load, such as a light bulb or motor, that uses the electricity.
2. How do I build a simple electric circuit?
To build a simple electric circuit, you will need a power source, wires, and a load. First, connect the positive (+) end of the power source to one end of the wire, and the negative (-) end to the other end. Then, connect one end of the wire to the load and the other end of the load to the negative end of the power source. This creates a complete circuit and allows the electricity to flow through the load, causing it to turn on.
3. What is the role of a switch in a simple electric circuit?
A switch is used to control the flow of electricity in a circuit. It can be opened or closed to either allow or block the flow of electricity. This allows you to turn the circuit on or off, or to control when the load receives electricity.
4. How do I calculate the voltage and current in a simple electric circuit?
The voltage in a simple electric circuit is determined by the power source, and the current is determined by the resistance of the circuit. The equation V=IR (voltage = current x resistance) can be used to calculate the voltage or current in a circuit. The resistance can be measured with a multimeter, and the voltage and current can be measured with a voltmeter and ammeter, respectively.
5. What are some common safety precautions when working with simple electric circuits?
When working with simple electric circuits, it is important to always turn off the power source before making any changes to the circuit. Always handle wires and connections carefully to avoid electrical shocks. Never touch exposed wires or components while the circuit is powered on. It is also important to use the correct voltage and current ratings for components to avoid damaging them or causing a fire. Always wear protective gear, such as gloves and safety glasses, when working with electricity.
