Help with solving a probability question
In summary, there is a problem involving 27 pieces of luggage, of which 4 are randomly selected and damaged. The probability that exactly one of the damaged items is insured is twice the probability that none of the damaged pieces are insured. To calculate the probability that exactly two of the four damaged pieces are insured, we must use Bayes' Theorem and set the equations for P(one of the damaged items is insured) and P(none of the damaged items are insured) equal to each other. This results in a solution of r=8 for the number of insured items among the 27 pieces of luggage.
theone
81
From 27 pieces of luggage, an airline handler damages a random sample of 4.
Calculate the probability that exactly two of the four damaged pieces are insured.
From the second line,
"P(one of the damaged items is insured) = 2 x P(none of the damaged pieces are insured)"
Assuming that the probability of one of the 27 luggage being insured is r/27, I'm trying to work out the two probabilities in the second line... so that I can solve for r, and then use that to answer the actual question "Calculate the probability that exactly two of the four damaged pieces are insured"
I am confused about working out the two probabilities in the second line.
For P(one of the damaged items is insured)... is the answer that there are four possibilities where one of the four damaged items is insured,so:
4 (r/27)(27-r-1/26)(27-r-2/25)(27-r-3/24) ?
I don't think you can assume the probability of one is x/27 from the info given. I think you will need to use Bayes Theorem (P of A given B) to solve this.
That looks Ok to me. Set it equal to a similar expression for the other probability. You should be able to cancel several factors from both sides and see if you can solve for r. I hope r turns out to be an integer.
I found a solution online and it takes the r/27 approach so I think have to go with that
P(one of the damaged items is insured) = 4 (r/27)(27-r-1/26)(27-r-2/25)(27-r-3/24)
P(none of the damaged items are insured) = (27-r/27)(27-r-1/26)(27-r-2/25)(27-r-3/24)
For the first probability I multiplied by 4 because 4 patterns of having one insured item among 4 items. Similarly am I supposed to be multiplying the second by something?.I am a little confused thinking about this.. should I be accounting for all of the possible non-insured items that could have ended up being in the random sample of 4 damaged items
Use your original equation, P(one of the damaged items is insured) = 2 x P(none of the damaged pieces are insured), and see where that takes you.
With
I end up with r=9
But according to the solution, I should be getting r=8
I see one problem with 4 (r/27)(27-r-1/26)(27-r-2/25)(27-r-3/24). For the first non-insured selection, there are 27-r non-insured, not 27-r-1.
you're right, that's the mistake. I am now getting r=8 as I should
I am also confused about the meaning of independent vs dependent. Does all it mean is whether you are replacing after each selection or not? So if its was independent, would it be:
4 (r/27)(27-r/27)(27-r/27)(27-r/27) ?
Independence in this case means that you are treating the 27 pieces of luggage as independent, each with the same probability of being insured. The problem and your solution assume this.
If, instead, all 27 pieces of luggage belonged to the same party, then they you could say that either they are all insured or they are all uninsured. In this case, whether one piece of luggage is insured would depend on whether the other pieces were insured. Then the problem wouldn't make much sense.
Once you start drawing, replacement makes it so that the next drawing does not depend on what happened in the first drawing. So you are correct. Without replacement, the following probabilities are modified as you calculated. That makes them dependent results.
The problem says that 4 pieces of luggage are damaged. The handler selects each piece of luggage in turn, processes it, and in the process may or may not damage it. In this problem we know everything relevant about every piece of luggage: 23 are undamaged and 4 are damaged. Replacement or not doesn't enter into the problem.
A different problem might involve quality control of luggage to see how many are damaged. In that type of problem replacement may be a factor.
The damage is merely the selection process, not the insured/uninsured probability. The probabilities are associated with the insured/uninsured within the 27. There is no replacement, so the probability of the second damaged luggage being insured is changed by whether the first was insured.
Okay, so the problem should read:
From 27 pieces of lugguge, ##r## of which are insured ...
Rather than, how I interpreted it:
There is a probability of ##p## that a random piece of airline luggage is insured ...
Related to Help with solving a probability question
1. What is probability?
Probability is the likelihood or chance of a particular event occurring. It is expressed as a number between 0 and 1, where 0 indicates impossibility and 1 indicates certainty.
2. How do you calculate probability?
To calculate probability, you divide the number of favorable outcomes by the total number of possible outcomes. This gives you a decimal value, which can be converted to a percentage by multiplying by 100.
3. What is the difference between theoretical and experimental probability?
Theoretical probability is based on mathematical calculations and predictions, while experimental probability is based on actual results from experiments or observations. Theoretical probability is often used in situations where all outcomes are equally likely, while experimental probability is used when outcomes may not be equally likely.
4. Can probability be greater than 1 or less than 0?
No, probability cannot be greater than 1 or less than 0. A probability of 1 indicates certainty, while a probability of 0 indicates impossibility. Any value outside of this range would not make sense in the context of probability.
5. How can probability be used in real life?
Probability is used in many real-life situations, such as in weather forecasting, gambling, and risk assessment. It can also be used to make predictions and decisions based on the likelihood of certain events occurring.
