Help with Solving Limit of Cosine and Sine
In summary, there are multiple ways to solve the limit $\displaystyle\lim_{x \to 0}\frac{\cos(x)-1}{\sin(x)}$, including using the double angle identity, substitution, and the limit properties of sine and cosine. No matter which method is used, the final answer is 0.
Petrus
702
Hello,
I got problem solving $$\lim_{x \to 0}\frac{\cos(x)-1}{\sin(x)}$$
I do not really get any progress, I would be glad if someone could give me tips!
Re: Trig limit
There are many ways to solve it :
you may use : \(\displaystyle \cos(2x)= 1-2\sin^2(x)\)
you may also differentiate both numerator and denominator (LH rule)
series expansion ...
Re: Trig limit
Are you familiar with l'Hôpital's rule, or are you meant to find the limit a particular way?
Re: Trig limit
No I do not want to use l hopitals rule. I could not understand that tips u gave me with cos(2x).
basicly I think ima divide and multiplying. Thats what My book have done on example and i read on this chapter
Re: Trig limit
Since we have the double angle identity :
so \(\displaystyle \cos(2x)-1= -2\sin^2(x)\)
But there we have cos(x) so Let us generalize
\(\displaystyle \cos(angle) -1 = -2\sin^2(angle/2) \)
so we have \(\displaystyle \cos(x)-1= -2\sin^2\left(\frac{x}{2}\right)\)
Re: Trig limit
Petrus said:
Hello,
Setting $\displaystyle x= 2\ \theta$ and considering that is... $\sin 2\ \theta = 2\ \sin \theta\ \cos \theta$
$\cos 2\ \theta = 1 - 2\ \sin^{2} \theta$ (1)
... You arrive to write...
$\displaystyle \lim_{x \to 0}\frac{\cos(x)-1}{\sin(x)}= \lim_{\theta \rightarrow 0} - \frac{\sin \theta}{\cos \theta} =0 $ (2)
Kind regards
$\chi$ $\sigma$
Re: Trig limit
Hello,
Does it work if I use $\cos^2(x)+\sin^2(x)=1$ and rewrite as $\cos^2(x)-1=-\sin^2(x)$
and at last step I get
$$\lim_{x \to 0} \frac{-\sin(x)}{\cos(x)+1}=-0/2=0$$.
Note that i simplifie before last step
Re: Trig limit
Hello ZaidAlyafey,
If you possible got time I would be glad if you could show me step by step on your way. I would really be glad if I could solve this problem on diffrent way:) (I could unfortenetly not solve with your way)
Re: Trig limit
Ok , I will use the facts :
\(\displaystyle \cos(x)-1=-2\sin^2\left(\frac{x}{2}\right)\)
\(\displaystyle \sin(x) = 2\sin\left(\frac{x}{2}\right) \cos\left(\frac{x}{2}\right)\)
So substituting this in our limit we get :
\(\displaystyle \lim_{x\to 0}\frac{-2\sin^2\left(\frac{x}{2}\right)}{2\sin\left(\frac{x}{2}\right) \cos\left(\frac{x}{2}\right)}=\lim_{x \to 0}\frac{-\sin\left(\frac{x}{2}\right)}{\cos\left(\frac{x}{2}\right)}=\frac{0}{1}=0\)
Re: Trig limit
Thanks!
(This was My bad... I was not thinking correct.. I was just rewriting cos and not sin... Darn next time I have to think about this...)
Re: Trig limit
Petrus said:
Hello,
Does it work if I use $\cos^2(x)+\sin^2(x)=1$ and rewrite as $\cos^2(x)-1=-\sin(x)$
No , you are missing a square , $\cos^2(x)-1=-\sin^2(x)$
Re: Trig limit
Thanks! Forgot when i wrote it on pc!
Re: Trig limit
Petrus said:
Hello,
I would rewrite the expression as follows:
\(\displaystyle \frac{\cos(x)-1}{\sin(x)}\cdot\frac{\cos(x)+1}{\cos(x)+1}=\frac{\cos^2(x)-1}{\sin(x)(\cos(x)+1)}=\frac{-\sin^2(x)}{\sin(x)(\cos(x)+1)}=-\frac{\sin(x)}{\cos(x)+1}\)
and so:
\(\displaystyle \lim_{x \to 0}\frac{\cos(x)-1}{\sin(x)}=-\lim_{x \to 0}\frac{\sin(x)}{\cos(x)+1}=-\frac{0}{1+1}=0\)
This is essentially what you did when you tried using a Pythagorean identity, but I wanted to clearly lay out all the steps.
Re: Trig limit
Petrus said:
Hello,
There is yet another way to do this one if you're allowed to use the facts that $\displaystyle\lim_{x\to 0}\frac{\sin x}{x}=1$ and $\displaystyle\lim_{x\to 0}\frac{1-\cos x}{x}=0$.
Then it follows that
\[\lim_{x\to 0}\frac{\cos x -1 }{\sin x}=\lim_{x\to 0} \frac{-\dfrac{1-\cos x}{x}}{ \dfrac{\sin x}{x}}= -\frac{\displaystyle\lim_{x\to 0} \frac{1-\cos x}{x}}{ \displaystyle \lim_{x\to 0}\frac{\sin x}{x}} =-\frac{0}{1}=0\]
I hope this makes sense!
Re: Trig limit
You can also work with taylorseries.
We have
$\sin(x) = x-\frac{x^3}{3!}+\frac{x^5}{5!}-\frac{x^7}{7!}+\ldots$
$\cos(x) = 1-\frac{x^2}{2!}+\frac{x^4}{4!}-\frac{x^6}{6!}+\ldots$
We obtain
$\displaystyle \lim_{x \to 0} \frac{\cos(x)-1}{\sin(x)} = \displaystyle \lim_{x \to 0} \frac{\left(1-\frac{x^2}{2!}+\frac{x^4}{4!}-\frac{x^6}{6!}+\ldots\right)-1}{x-\frac{x^3}{3!}+\frac{x^5}{5!}-\frac{x^7}{7!}+\ldots} = \lim_{x \to 0} \frac{-\frac{x^2}{2!}+\frac{x^4}{4!}-\frac{x^6}{6!}+\ldots}{x-\frac{x^3}{3!}+\frac{x^5}{5!}-\frac{x^7}{7!}+\ldots}$
$=\displaystyle \lim_{x \to 0} \frac{x \left(-\frac{x}{2!}+\frac{x^3}{4!}-\frac{x^5}{6!}+\ldots\right)}{x \left(1-\frac{x^2}{3!}+\frac{x^4}{5!}-\frac{x^6}{7!}+\ldots\right)} = \frac{0}{1}= 0$
Re: Trig limit
Are we running out of methods :confused: ...
Re: Trig limit
Well, there is still L'Hôpital's rule, but Petrus has stated he wished not to use this method. (Mmm)
Re: Trig limit
We could still try the squeeze rule...
Also pretty standard for this type of problem.
Re: Trig limit
We have
We obtain
This method have to wait:P Havent read about Taylor yet:)
Re: Trig limit
Hello,
In exam would you guys prefer lhopitals rule? Well for me it seems like A easy trick. I try always solve with lhopitals rule and without, don't want to get stuck with just going for lhopitals.
(Edit: I want to Clear that i am not saying that derivate is simple but most of limits of My book don't have really have difficoult to derivate. I want to also say yes i know to be able to use lhopitals i have to check if original function is $\frac{0}{0}$ $\frac{\infty}{\infty}$ $\frac{-\infty}{-\infty}$ and yes i know My infinity latex code does not work and i do not know how to get it correct)
Re: Trig limit
If you're allowed to use l'Hopital in an exam why not use it?
To get infinity in latex use \infty ($\infty$).
As for yet another way to get the limit with the squeeze theorem...
If $x > 0$ we have:
$$- \frac {x^2} 2 \le \cos x - 1 \le 0$$
$$0 \le \sin x \le x$$
It follows that:
$$\frac{- \frac {x^2} 2}{x} \le \frac{\cos x - 1}{\sin x} \le \frac 0 {\sin x}$$
$$- \frac {x} 2 \le \frac{\cos x - 1}{\sin x} \le 0$$
Since the left and right hand side both approach zero if x approaches zero, it follows by the squeeze theorem that:
$$\lim_{x \downarrow 0} \frac{\cos x - 1}{\sin x} = 0$$
Similarly we can find that:
$$\lim_{x \uparrow 0} \frac{\cos x - 1}{\sin x} = 0$$
So it follows that:
$$\lim_{x \to 0} \frac{\cos x - 1}{\sin x} = 0 \qquad \blacksquare$$
Re: Trig limit
It has been my experience that in the vast majority of cases, L'Hôpital's rule is the most straightforward way to handle indeterminate forms. Even if you are instructed to use another method, it is a good tool to use to check your results.
Re: Trig limit
Unfortunately there are unfrequent cases in which l'Hopital rule is a wrong way... for example let's suppose to have the following limit...
$\displaystyle \lim_{x \rightarrow 0} \frac{x^{2}\ \sin \frac{1}{x}}{\sin x}$ (1)
Applying l'Hopital rule You arrive to the expression...
$\displaystyle \frac {2\ x\ \sin \frac{1}{x} - \cos \frac{1}{x}}{\cos x}$ (2)
... which has no limit if x tends to 0. If You proceed 'directly' however You obtain...
$\displaystyle \lim_{x \rightarrow 0}\ \frac{x^{2}\ \sin \frac{1}{x}}{\sin x} = \displaystyle \lim_{x \rightarrow 0}x\ \frac{x}{\sin x}\ \sin \frac{1}{x} = 0$ (3)
Kind regards $\chi$ $\sigma$
Re: Trig limit
Of course the example I reported could be given to a student in an exam test and in that case the reccommendation don't to use l'Hopital test would be essential. But does that type of 'decency' ever used by teachers?... Kind regards $\chi$ $\sigma$
Re: Trig limit
Hello,
Sorry making this many page but i never knew about this. Why does this happend? I know for example equation you can get fake root but what is the reason here?
Re: Trig limit
Petrus said:
Hello,
If we limit the analysis to the $\frac{0}{0}$ case, the l'Hopital's theorem extablishes that, under appropriate conditions on f(*) and g(*), if the limit $\displaystyle \lim_{ x \rightarrow 0} \frac{f^{\ '} (x)}{g^{\ '} (x)}$ exists, then also the limit $\displaystyle \lim_{ x \rightarrow 0} \frac{f(x)}{g(x)}$ exists and is... $\displaystyle \lim_{ x \rightarrow 0} \frac{f(x)}{g(x)} = \lim_{ x \rightarrow 0} \frac{f^{\ '} (x)}{g^{\ '} (x)}$ (1)
... so that if You have an 'indeterminate form' $\displaystyle \frac{f(x)}{g(x)}$ it is not guaranted that l'Hopital's rule solves the 'endedness'. The fact that the 'universal certainty' is that l'Hopital's rule can be 'automatically used' any time You meet an 'undeterminated form' shows, in my opinion, how superficially Math is often teached... Kind regards $\chi$ $\sigma$
FAQ: Help with Solving Limit of Cosine and Sine
What is the limit of cosine and sine?
The limit of cosine and sine is 1 as x approaches 0. This means that as x gets closer and closer to 0, the value of cosine and sine approaches 1.
How do I solve the limit of cosine and sine?
To solve the limit of cosine and sine, you can use the trigonometric identities of cosine and sine, such as the double angle identity, to simplify the expression and then use basic algebraic techniques to evaluate the limit.
Can the limit of cosine and sine be undefined?
Yes, the limit of cosine and sine can be undefined if the expression contains a discontinuity, such as a vertical asymptote or a point where the function is not defined.
Why is the limit of cosine and sine important?
The limit of cosine and sine is important in calculus and other areas of mathematics because it helps us understand the behavior of these trigonometric functions as x approaches a certain value. This can be useful in finding derivatives, solving integrals, and analyzing curves and functions.
Are there any special cases for the limit of cosine and sine?
Yes, there are special cases for the limit of cosine and sine, such as when the expression involves a fraction with a variable in the denominator. In these cases, you may need to use L'Hopital's rule or other techniques to evaluate the limit.
