Help with solving parametric equation
In summary, the parametric curve x=5cos^7(t) and y=5sin^7(t) can be written in cartesian form as x^(2/7) + y^(2/7) = 1.
53Mark53
52
Consider the following parametric curve:
x=5cos^7(t)
y=5sin^7(t)
Write it in cartesian form, giving your answer as an equation of the form F(x,y)=c for some function F and some constant c.
[/B]
I know that sin^2(t)+cos^2(t) = 1 but I don't think this will be much help to figure this out and I am also unsure how I would find the constant
Any help would be much appreciated
Why not? How are ##x## and ##y## related to ##\sin^2(t)## and ##\cos^2(t)##?
would that mean x^2+y^2 = 1
which would mean
(5cos^7(t))^2 +(5sin^7(t))^2 = 125cos^9(t) +25sin^9(t) = 1
But what would I do now?
Nope, that is not correct. Try to express ##\sin^2(t)## in terms of ##y## and ##\cos^2(t)## in terms of ##x##.
would that mean
y=1-cos^2(t)
x=1-sin^2(t)
53Mark53 said:
would that mean
y=1-cos^2(t)
x=1-sin^2(t)
No, why would you think that?
You already have ##x## and ##y## defined in your original post: ##x = 5 \cos^7(t)## and ##y = 5 \sin^7(t)##.
Can you manipulate ##x = 5 \cos^7(t)## to get ##\cos^2(t)## in terms of ##x##? And likewise for ##\sin^2(t)## in terms of ##y##.
x=5cos^7(t)
y=5sin^7(t)
[/B]
To start: Solve
##x=5\cos^7(t) ##​
for ##\ \cos(t)\ .##
SammyS said:
To start: Solve
##x=5\cos^7(t) ##​
cos(t)=(x/5)^(7/2)
Is this correct?
53Mark53 said:
cos(t)=(x/5)^(7/2)
Is this correct?
No. The exponent is wrong.
cos(t)=(x/5)^(1/7)
What would i do now?
53Mark53 said:
cos(t)=(x/5)^(1/7)
That's better.
Do similar for y.
Square each & add.
Likes 53Mark53
SammyS said:
That's better.
Do similar for y.
Square each & add.
Thanks I got the right answer now!
Related to Help with solving parametric equation
What is a parametric equation?
A parametric equation is a set of equations that describe the relationship between two or more variables. In these equations, each variable is represented in terms of a third variable, known as the parameter.
Why are parametric equations useful?
Parametric equations are useful because they allow us to represent complex curves and shapes in a more simplified manner. They also make it easier to analyze and manipulate mathematical models and systems.
How do I solve a parametric equation?
The process of solving a parametric equation involves finding the values of the variables that satisfy the equations. This can be done by eliminating the parameter and solving for the remaining variables, or by graphing the equations and identifying the points of intersection.
What are some common applications of parametric equations?
Parametric equations are commonly used in physics, engineering, and computer graphics to model and analyze motion, curves, and surfaces. They are also used in economics and finance to model systems with changing variables.
What are some tips for solving parametric equations?
Some tips for solving parametric equations include identifying the parameter, eliminating it if possible, and using substitution or graphing to solve for the variables. It is also important to pay attention to any restrictions on the variable values and to check the solutions for accuracy.
