Help with triple integration problem
In summary, the conversation was about a triple integration problem using spherical coordinates to find the volume of a small part of a sphere. The given values were rho from 5 to 6, phi from pi/6 to pi/4, and theta from pi/4 to pi/3. The answer given by one person was (-91/72) x pi x (sqrt(2)-sqrt(3)), to which another person responded with a simplified answer of (6^3-5^3)/3 x (pi/3-pi/4) x (cos(pi/6)-cos(pi/4)), stating that it is correct if it is just a simplification of the original answer. There was a brief discussion about the
mister_okay
hey! i need some help with a triple integration problem using spherical coordinates. it's the volume of a small part of a sphere. rho from 5 to 6, phi from pi/6 to pi/4 and theta from pi/4 to pi/3.
i got an answer of (-91/72) x pi x (sqrt(2)-sqrt(3))...am i right? Thanks!
Well, the answer ought to be:
[tex]\frac{6^{3}-5^{3}}{3}(\frac{\pi}{3}-\frac{\pi}{4})(\cos\frac{\pi}{6}-\cos\frac{\pi}{4})[/tex]
So, if your answer is just a simplification of this, then it is correct.
EDIT:
Yup, it is correct.
Hey thanks arildno :)
but one question..
shouldnt it be cos(pi/4)-cos(pi/6) instead of cos(pi/6)-cos(pi/4)?
No, since:
[tex]\int_{\frac{\pi}{6}}^{\frac{\pi}{4}} sin\phi d\phi = [-cos\phi]_{\frac{\pi}{6}}^{\frac{\pi}{4}} = -cos(\frac{\pi}{4}) - (-cos(\frac{\pi}{6})) = cos(\frac{\pi}{6}) - cos(\frac{\pi}{4})[/tex]
oh ok...forgot about the negative. thanks!
Related to Help with triple integration problem
1. What is triple integration?
Triple integration is a mathematical process used to calculate the volume of a three-dimensional shape. It involves integrating a function over a three-dimensional region using the three variables x, y, and z.
2. How do I solve a triple integration problem?
To solve a triple integration problem, you need to first determine the limits of integration for each variable, then set up the integrals using the appropriate functions. Next, you evaluate the integrals and multiply the results to get the final solution.
3. What are some common applications of triple integration?
Triple integration is commonly used in physics, engineering, and other fields to calculate volumes, masses, and other physical quantities. It is also used in geometric and vector calculus to solve problems involving three-dimensional shapes and surfaces.
4. What are some tips for solving triple integration problems?
Some tips for solving triple integration problems include visualizing the three-dimensional region, breaking the problem into smaller parts, and using symmetry to simplify the integration process. It is also important to carefully set up the integrals and evaluate them accurately.
5. What resources are available for help with triple integration problems?
There are several resources available for help with triple integration problems, including textbooks, online tutorials, and software programs that can assist with calculations. You can also seek help from a math tutor or your professor for additional guidance and practice problems.
  • Calculus
  • Calculus
