Arv
- 6
Hi
I am currently involved in building a linear motor which is based around the coil gun principle. I am having trouble understanding the equation for force used to desribe the coilgun's action.
namely:
Fx = I1*I2*dM/dX
Fy = I1*I2*dM/dX
Here we are considering two coils of wire, with an rapidly
changing current allowed to flow through one of the coils (The active coil)which in turn induces a current in the nearby 'passive' coil (via Lenz Law). So I1 is the active current and I2 is the passive current.
So bascially u end up with two magnetic poles with same polarity next to each other and there is a repulsion action. If the vertical movement is constrained, you are left with horizontal thrust which is what the linear motor makes use of.
I can relate this force equation to physics textbooks' description of force betweentwo parallel current carrying conductors which uses the Lorentz Force equation (F = I*L*B) and Magnetic Field near straight wire (B = mu*I/(2*PI*R) to arrive at F = (mu*I1*I2)/(2*PI*D).
I don't how to explain the dM/dX part.
Can someone help me get from the F = I*L*B description to the
F = I*dM/dX description.
The M in dM/dX is the mutual inductance which is the coefficient that
describes the linking flux between the two coils. Why should the force
depend on a gradient in mutual inductance? Can someone offer
an intuvitive explanation for this or perhaps provide a sketch of a proof
which I can work on?
Thanks
Arv
namely:
Fx = I1*I2*dM/dX
Fy = I1*I2*dM/dX
Thanks
Arv
