Help With Understanding Thrust Calculations (rifle muzzle brake)
The discussion revolves around the calculation of thrust on a baffle of a muzzle brake using two different equations, which yield significantly different results. Equation 1, derived from The Engineering Design Handbook, produces higher thrust values compared to Equation 2 from Armament Engineering, raising concerns about the reliability of the calculations. The user expresses a preference for Equation 2, as its results seem more realistic, but worries about potential material failure if Equation 1 is more accurate. Additionally, it is noted that shorter barrel systems generate more thrust on the baffle than longer barrels due to the distribution of combustion pressure and energy. The conversation highlights the complexities in thrust calculations and the implications for design safety and performance.
Ozen
TL;DR Summary
I have two equations for thrust on a muzzle brake, however they each yield different results, which is correct?
Let me start off by saying I decided to post this in the aerospace engineering thread because it directly deals with thrust, even though it is not for a plane or similar.
I have two equations that I can use to calculate the force on a baffle of a muzzle brake, Equation 1, from The Engineering Design Handbook Series, and Equation 2, from Armament Engineering, a computer aided approach. But both yield different results with the same inputs (even when converted to there correct counterpart. Equation 1 yields significantly higher results than equation 2. Below is a run-down on solving them both for the same given system, note that they don't use the same variables always.
Givens:
Ae = .000029 m^2 (bore area)
mc = .00169 kg (charge mass)
mp = .00402 kg (projectile mass)
Vt = 9.2E-06 m^3 (16in barrel volume); 3.5E-06 m^3 (7in barrel volume)
vo = 892 m/s (muzzle velocity); 650 m/s
pe = 5.52E+07 PA; 1.17E+08 PA (chamber pressure)
lambda = 1.64 (factor)
Ct = 2.21 (correction factor)
RT0 = 700119 m^2/s^2 (gas constant * average temperature of gas at shot ejection)
pmz = pe * (1 - (mc / (2 * mp +mc)) (pressure at muzzle exit)
Equation 1:
Fb = 0.26 * lambda * Ct * (mc / Vt) * Ae * RT0 * (1 + (mc / 6 * mp))
***Units must be in imperial, all were converted to their correct correspondent before computing
Solved:
16in barrel: Fb = 9385 N
7in barrel: Fb = 29389 N
Doesn't this seem rather odd? Almost triple the force for a system that has lower velocity, lower volume, and higher pressure.
Equation 2:
Fb = pmz * Ae * lambda * Ct
***Units must be metric, same as above
Solved:
16in barrel: Fb = 4794 N
7in barrel: Fb = 10162 N
My Question:
Which equation should I use? I lean towards Equation 2 since that seem more realistic, but if that is wrong, the material may yield and break when I would test a design. Or worse, the design could work for testing but have a bad fatigue life and end up breaking not long after.
***Supplemental question: Why do shorter barrel systems produce more thrust on the baffle than the longer barrel systems?
Both short and long barrels will have the same peak combustion pressure, but the longer barrel puts more of that energy into bullet velocity. The pressure is lower at the point where the bullet leaves the muzzle with the longer barrel.
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
